Question about Konica Minolta Bizhub C353 Copier
Getting a wavy black background print when copying or printing on konica minolta bizhub C352
When printing or copying there are wavy black jagged lines on the entire background of the page. They look similar to heartbeat lines. What could be the problem
  • 214 Answers
SOURCE: paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Posted on May 11, 2008
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
Bizhubman
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
xeerie
  • 347 Answers
SOURCE: bizhub c352 imaging units not recognized after replacing PWB-M ?
Upgrade firmware then install imaging units.
Posted on Jun 05, 2012
sladdin810
  • 3 Answers
SOURCE: How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
Posted on Oct 08, 2012
How to remove dark background on bizhub 350
Make multiple copies of Jet black print for example, open the platen cover and then make blank copies.Print out will be jet black.After about 60 to 70 copies background will be adjusted, if not then replace the toner.After replacing the toner if the background is still there then you must replace the developer.
Feb 11, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Printing black ground in konica minolta bizhub c220
have a tech come out clean the machine run require procedures to determine problem
Apr 26, 2014 | Konica Minolta Bizhub C220 Color Copier
"Konica Minolta C352 - cyan and white pattern background on every print?!
What are you printing a Word document when this happens ?
suspect pattern may be in the software you are printing from.
Go to software help screen and look search for removing background pattern or removing watermark.
Apr 11, 2014 | Konica Minolta Bizhub C352 Digital Copier
When a print job is sent to my Konica Minolta Bizhub c352, it only flashes "data" light, but nothing prints.
Does this happen when you copy. Try different document and program pdf word web page etc. Static IP or DHPC? Recommend static IP for copier/printers
Feb 14, 2014 | Konica Minolta bizhub C250 All-In-One...
I have the bizhub C352 - I want to print the utility/counter (meter readings). How do i do that. Previous machines had me go to Utility - admin management - copy track - Copy track data - & hit the...
to print meter readings perform these steps. 1-press "utility/counter" 2-press "details" 3-now at the left side of the screen you will see a "print" button, press it and get your copy.
Oct 20, 2010 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub C353 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
