Question about Toshiba 34HFX83 34" TV
Ever since I hooked up my tv it turned on by it self and
Well ever since I hooked my tv it turned on by it self, the buttons on the front panel are not working, and the romote does not work either including the power button. Does this require service or am I jus missing something
  • charlie perry Jul 02, 2007
    hahah yeah it was something simple yet it needed to be looked in side of it.... It was the sensor chip while the tv was being moved here it must have been bumped and it was knocked loose.
  • 934 Answers
It's time to bite the bullet and take it to the shop... Could be tac switches, or problems with the jungle IC, micro or eprom. You'll need some testing with a scope to determine which... Good Luck Bill
Posted on Jun 10, 2007
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Can only access 3 input select programs. and I need one of the others to hook playstation up. It just skips right over it
To Reset the Unit, turn the TV on and while pressing the "VOLUME ( - )" button on the main unit, press the "Menu" button on the remote control for more than 3 seconds. The Self-Check menu appears on screen. Then, disconnect the AC cord from the wall outlet
Feb 11, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The input function is not working and the t.v. is on but no picture. Blank screen. Was working last night just fine we tried to hook up Xbox and when the input button was pressed screen went blank. any...
Perform Reset From Front panel of Tv, wait until green light stops blinking, set is running self diagnostic. If that doesn't work, it could be something in the DMD Panel containing the Digital Micromirror Device
Oct 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
I HAVE A JVC AV-3290S TV REMOTE DOES NOT WORK AND I CANNOT GET THE TV ON CHANNEL 3 TO WORK WITH CABLE
Try using the video input connectors using the front panel buttons to select. or hook up the cable box so your sure the TV is receiving the signal and then select autoprogamming through the front panel buttons
Oct 04, 2009 | Televison & Video
Samsung pn50a450 plasma TV turned off by itself
first unplug it for 10 min then retry it. otherwise it is the power supply, the low voltage and high voltage supply are on the same board, have your tech send it in to be rebuilt if he is unable to do it him or her self.
Jul 23, 2009 | Televison & Video
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Need manual
does your tv have a round button in the front of the tv push it then see if it turns on.
Nov 09, 2008 | Televison & Video
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Speaker off
You will need an original Mitsubishi remote. The original remotes usually have 3 large oval buttons labeled Audio (up and down), Adjust (up and down) and Video (up and down). Pressing the Audio button will bring up the usual Bass, Treble, Balance... and Speakers Off. When you see those words press the Adjust button and the speakers will switch to On. Some sets have the Audio, Adjust and Video buttons behind a little door on the front of the set, so check there first and if not, get an original remote.
Dec 29, 2006 | Mitsubishi CS-27407 27" TV
Toshiba 34HFX83 34" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
