Question about Refrigerators
My sub zero got flooded with salt water could it be fixed 600 series
Electric on bottom
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
No, not if saltwater got into it!
Posted on Nov 30, 2012
Master_Tech
  • 770 Answers
SOURCE: Sub-Zero 600 Series Ice maker has
have you checked the water supply?
Posted on Jul 09, 2008
SOURCE: Sub-Zero freezer 600 series -
Our is doing the same thing, except we do not have ice forming on the back of the freezer. We were told by a refrigeration repair company that if ice is forming on the back of the freezer then the compressor is bad.
Posted on Sep 22, 2008
SOURCE: sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Posted on Oct 08, 2008
  • 56 Answers
SOURCE: installing cams to sub zero 550
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code is the locator area parts distributors. Once you get the parts in, remove everything from the door, food, shelves.... Then with the door closed remove the upper hinge. If you have a left hinge unit you can bend the shroud out of the way and bend it back when you are done. The door can be quite heavy if you have wood panels on it so you may need help. Open the door 90 degrees and lift up and over the bottom hinge. Remove the cam from the door using a phillips head screw. Then replace the hinge cam that is on the hinge that is still attached to the body. Now you will need help, lift the door up and have some one set it into the lower hinge pin. Close the door and have some one hold it closed while you climb up and reinstall the hinge. You may have to adjust the door by sliding it forward and back left and right until you get your sight line just right.
Posted on Dec 16, 2008
  • 56 Answers
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
Sub zero bottom freezer stuck and will not open
ice maker could have flooded over or the drain for defrost water is blocked and water is leaking into freezer.you have to shut down the freezer until you can get the door open parcially and then melt out the rest with a hair dryer,also shut off the water to the fridge in case it's from the ice maker and then find out where the water is coming from,if it's on the left side it will be from the ice maker,if it's on the right side it's the drain,if it's the drain you can buy a heater kit,a little tricky to install,you have to snake a piece of fishing line down through the tube to snake the heater into the drain and then wire it in so the heater will keep any ice freezing in the drain again,it comes with directions part number 4202160.you might want to call in a tech for this unless you're handy fixing things,but first find out if it's the drain or the ice maker
Mar 11, 2012 | Sub-Zero Bottom Freezer Refrigerator
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
