Question about Kicker Comp C12 Car Subwoofer
C12 how to wire 2 to 1 ohm - Kicker Comp C12 Car Subwoofer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
What you want to fry your amp guy?
Posted on Dec 03, 2012
Would a Kicker DX250.1 250W 2-Ohm Mono Class D amp work well with a kicker dual 12" c12 subwoofer with 600watt peak?
you really want something closer to 600 watts. if you arent careful, you can overdrive the amp, since the speaker isnt seeming to mind the volume, and the resulting audio distortion can damage the speaker
Jun 19, 2015 | Kicker Car Audio & Video
I got the code p1361 on my HONDA, PRELUDE, 2000. Its mean TDC intermittent connection.... On h22a4 like me... the TDC and CKP connect in 1 connector. I check the connector restistance.... perfect... i...
heres adiagram to check resistance of the sensor, it should be1200-1300 ohms, but take note the sensor could read good at this time this problem is intermitent and the sensor may be bad, check for continuty at the computer connector , if all wires are good then i would replace the crankshaft sensor/top dead sensor (CKP/TDC).next check conntinuty between sensor terminals and ground check all four prongs on sensor if theres continuity on any one replace sensor, next key off and sensor connected . remove the pcm 31 pin connector (C) here a diagram of it. at the pcm connector measure resistance between terminals C2 and C12 it should be 1200-3200 ohms, then check between C3 and C13, again 1200-3200ohms if the ohms are off then check wires that fail omh test.next test is with connector again test connector c2 (blue /white wire) to ground and C3 to ground if continuity exists then repair wire that fails between connector and sensor, if all tests are good then try a good pcm. i dont think its pcm, i think if its not a wire then replace sensor , but good luck and i hope this helps.johnjohn2_18.gifjohnjohn2_19.gif
Nov 11, 2010 | 1998 Honda Prelude
Got a c11 and a c12 on my suzuki tl1000r what does it mean
c11 Camshaft position sensor or circuit malfunction The signal does not reach to ECM for more than 2 sec. after receiving the starter signal. The CMP sensor wiring and mechanical parts. (CMP sensor, rear intake cam pin, wiring/coupler connection) c12 Crankshaft position sensor or circuit malfunction The signal does not reach to ECM for more than 2 sec. after receiving the starter signal. The CKP sensor wiring and mechanical parts.(CKP sensor, wiring/coupler connection)
May 20, 2010 | 1999 Suzuki TL 1000 R
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Kicker Comp C12 Car Subwoofer Logo
46 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
