Question about Electrolux Ovens
Stirrups in door hinge are not engage properly
Door removed, how do you engage stirrups to put door back on
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
SOURCE: How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Posted on Jan 09, 2010
  • 476 Answers
SOURCE: I removed the oven door and took out the hinge to
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Posted on Jan 14, 2010
jumptrout51
  • 3361 Answers
SOURCE: I've removed the door to
Grasp the hinge with a pair of pliers and pull out and downward until it catches in the open position slot.
It will be hard to pull.
Posted on Mar 21, 2011
  • 552 Answers
Take the door back off and try again. The hinge is not in the receptical all the way
Posted on Apr 13, 2011
How do you take the doors off Neff double oven
fully open door and lift up small metal stirrups on bottom of hinge then close door up to them grip door firmly and lift upwards ,there are videos on you tube for this also.
Feb 09, 2017 | Neff Ovens
Cannot put the oven door back on
Hi Elspeth:
Don't know what make or model you are dealing with, but from personal experience, here's what I dealt with.
- Oven door is mounted on spring loaded hinges. That's what keeps it in the closed position.
- To remove the door, it has to be fully opened, then lifted from close to the hinges, and slid out.
- To put the door back on, the hinges have to be in the "door open" position. Since they are spring loaded this can be tricky getting them into position.
- It's easier with a helper, one on each side....... slide the hinge legs into the slots. You'll need to lift the door slightly towards the closed position to allow the hinge legs to engage in the secure or latched position.
Hope this helps.
Cheers.
Dec 06, 2015 | Ovens
What do I do to replace the oven door after stirrups have snapped shut with the door off?
You will need to separate the inner and out panel in order to access and reset the hinges.
Mar 04, 2015 | Ovens
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Jan 18, 2009 | Thermador C301U Electric Single Oven
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door came off
Just found this posted by tech17 (THANK YOU SO MUCH!) and it worked!
POSTED BY TECH17:
i posted the solution under premium problems i don't know how that works but what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
May 11, 2008 | Whirlpool RBS305PDS Electric Single Oven
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
Whirlpool RF396LXE2 Oven
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
22 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
