Question about Toys
My HL-8091 mini rc heli remote control infrared not receive to my helicopter..WHY plizz Help ME
Help me pliz
  • 6 Answers
SOURCE: My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Posted on Jun 30, 2009
SOURCE: my john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Posted on Jan 03, 2010
Testimonial: "thanks very much, you are absolutely right about the problem. i had difficulty moving the blades so put some clingfilm (!) in the gap on the shaft."
SOURCE: what is the charge time for a swift infrared
when you plug the helicopter into the remote and turn it on a green LED illuminates. THis indicates that the charging has begun. When the green LED goes out the charge is complete. I found the charge time to be approximately 15 minutes with a fresh set of AA's. However, since the charge comes from the batteries in the remote the charge time will increase as the remaining power in the remote batteries decreases.
Posted on Jan 08, 2010
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Tip
Infrared RC Copters
Hi, everyone.
Ever since I saw the first advertisements on YouTube, some years ago, I wanted to acquire one of these little helis. When I finally acquired one, I had lots of fun until the little thing started to give me trouble.I own several of these mini-copters and have managed to maintan most of them in good working conditions for about 4 years now.
I would like to share some things that I have learned about RC Infrared Helis, specifically speaking, the airhogs RC helicopters.
First of all these little copters are not intended to be used outside home unless on a very calm day and on an area that has to be protected against sunlight, because sunrays interfere enormously with the IR beam with which the Infra-red light-emmiting controller communicates with the copter. I have found out that even while flying an air hogs copter indoors, when you get them close to a ray of sun shinning through a window, it suddenly drops to the ground.
Next, Most problems that I have encountered have to do with a combination of low battery power, plus trimming. In some of these copters, trimming can take a great deal of pulses before you can get them to fly right.
On the first models I would cut a cardboard fin and tape it to the front of the heli, below the nose and across form it, side to side to make it thrust forward.
Many times there were things like hairs or pieces of cobwebs attached to the axle of the back rotor, causing the heli to spin uncontrollably, even after trying to trimming it with the remote contol.
On other ocassions the copter wouldn't hold a charge even with fresh batteries on the controller. I learned that in time, the charger connector/plug may get dirty, so I usually spray the inner part of these connectors with a light coat of contact cleaner(available at any electronics store like Radio Shack) and then plug and unplug the connector a few times. This has worked fine with my older copters that have presented such problems.
on Sep 26, 2011 | Silverlit Toys Red Air Hogs R/C Havoc Heli...
Rc helicopter loses connection
Check the transmitter crystal (if it has one) and check the wires in the heli's receiver unit.
You should turn heli on wait 3-secs then turn transmitter on.
Dec 26, 2013 | Toys
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
I dont know what band my helicopter is on
I'd use band A and it always works, except that it makes my ihome turn on, switch modes and radio stations, so I use band c. To connect to the heli, turn the helicopter on, wait for a red light to blink inside, then throttle up and down on your remote. Then, your all set. Just do some preflight checks and have fun!
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
Walkera 37 remote heli
Swap over the two wires that go from the motor to the speed controller. NB. don't swap over the wires at the battery this will destroy the speed controller.
Feb 25, 2009 | Walkera Dragonfly #68 7 Channel 3D...
Toys Logo
137 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
