Question about Teledyne Laars Pool & Spa
I have a laars boiler model pncv0750nack2bxn it not tune on
4 Suggested Answers
SOURCE: laars boiler
It's likely the pressure switch. If the heater isn't enough water pressure through it it won't fire. I had the same problem with mine. Try bypassing the switch with a little piece of wire and see what happens.
I replaced my switch this year and it seems to be working fine. You might want to take the switch off and let water pump through the siphon hose for a few minutes.
Good luck.
B
Posted on May 26, 2008
SOURCE: have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Posted on Jan 05, 2010
  • 82 Answers
SOURCE: have a problem with a laars boiler the pilot keeps
How long does it stay lit (if at all)? It sounds like the thermocoupler (about 10 bucks). Good luck
My new Laars JVS 225 boiler make a whining noise when heating up. It does it on all zones. This was a replacement for a Teledyne Larrs that had a leak but ran quiet. IPressure is 15 lbs and temp is 155...
My new Laars NeoTherm boiler (NTH150) was making a whining noise soon after install. The noise was audible through most of the home. Replacing the air/gas blower solved the problem. Correct sizing of pumps is also important to reduce (water-flow related) noise. Having done all that my Laars boiler still isn't particularly quiet in its start-up and (modulating) operation. It should NOT be located below or next to a bedroom.
Nov 19, 2010 | Heating & Cooling
Boiler will not ignite when water is flowing through
What kind of boiler ? (make - model ) does the boiler work ok for the central heating
Apr 21, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
Have a problem with a laars boiler the pilot keeps
Dec 25, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have a problem with a laars mini therm ii boiler. the pilot keeps
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My TELEDYNE LAARS Boiler hammers when the main
the hammer is due to boiling inside some one has been messing with the safety controls or water to slow or no flow at all
Oct 03, 2009 | Jandy TELEDYNE LAARS GAS VALVE, PROPANE...
Pilot Flame will not ignite
Clean the pilot tube of rust or other debris.
Jul 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
My 4 years old LAARS boiler Makes whining noise when it's runing.
The tubes in the heat exchanger are most likely clogged with gunk, you can flush the boiler with tri-sodium phosphate. you must isolate the boiler from the system in order to acomplish this
Jul 06, 2009 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
Pool & Spa Logo
47 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
