Question about HP Laserjet Cp2025n Printer
Error code 59.f0 printer color laserjet cp2025
  • chhuon sarath Nov 30, 2012
    hp color laserjet CP2025 Error code 59.F0 wat you salosound
3 Suggested Answers
SOURCE: HP Laserjet CP2025
Printer says offline and yellow light is flashing on the back of the printer where you plug in the network cable. Changed cable but it makes no difference. Any suggestions please?
Posted on Jul 21, 2010
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
Posted on Jul 22, 2010
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Hp color LaserJet cp2025 59.c0 error how to fix it
59 errors indicate one of the motors have failed. It could be a bad motor but also a bad cartridge will overload a motor and cause the error as well. If you have spare cartridges, try changing them one at a time and restart between changes to see if the error goes away. Also if the error only happens when you start to print it might be the fuser motor.
Aug 27, 2015 | HP Office Equipment & Supplies
How to solve 57.01 error turn off then on in my hp color laserjet cp2025 printer
57.xxx codes almost always indicate a cooling fan problem. One of your cooling fans has probably ceased to function, the fan will most likely need to be replaced.
Sep 05, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
57.xxx codes almost always indicate a failed cooling fan. The fan will probably need to be replaced to get rid of the error code.
When i sand a test page the printer show an error 59.f0 what can i do
Pull the transfer unit out, and turn the white gear on the side. Not the one that turns the transfer belt--the one that causes the belt to push up against the toner cartridges. If the gear turns somewhat freely (it's not stuck), then reseat the transfer unit and see if the error goes away.
More comprehensive troubleshooting guide is here:
http://www.partsondemand.co.nz/uploads/97806/files/Feb_14_59.F0_error_Tech_Talk.pdf
But if it passes all the "checks" and you still have the error, check this out:
http://cincinnatiprinterrepair.com/hp-cp3525-59-f0
Apr 22, 2014 | HP CP3525N Color LaserJet Printer
Laserjet cp3525 error 59.f0
If it helps, I solved the error 59.F0 blowing on the sensors that are on the outer side (right door) under the edge of the transfer belt. You must remove the fuser and transfer. To locate the place to blow, craft and close the door stations toners, we see a long plastic slide guide in the machine with the door movement. Must blow into the small holes that are filled with dust with compressed dry air.
Good luck.
Jan 09, 2012 | HP CP3525N Color LaserJet Printer
HP Color LaserJet CP352dn 59.fo error
59.F0 ERROR
The primary transfer-alienation motor has experienced an error.
1. Check to ensure the ITB is installed correctly.
2. Run a sensor test to verify that the primary transfer disengagement roller is functioning. If not replace the sensor (SR17).
3. Run the primary transfer drive test in actuator drive mode. If not functioning replace the ITB (Intermediate transfer belt).
Jul 27, 2011 | HP Laserjet Cp2025n Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
Mar 27, 2009 | HP Laserjet Cp2025n Printer
HP Laserjet Cp2025n Printer Logo
142 people viewed this question
Seeker5211
Seeker5211
