Rca tv won't come on...green light flashing.
I have a rca 52in hdtv about 6yrs old...tv was on and went off. Now it won't come back on. Green light on the on button keeps flashing but the tv will not come on...I would like to know what you think is wrong...I was going to take the back off and look for I don't know what...but, I don't know what kind of screw driver it takes to get into it...I am 53 and a single lady..pretty much have to do eveything myself...Please help!
  • 2 more comments
  • grandmother4 Jan 11, 2009
    model#D124C104P then the other numbers on the back are...
    ATC221 and D52W20
    ATC221 and D52W20
    thank you
    Thank you so much for all your help jpactech. Im not sure if I can
    fix it myself but, I'm going to try.....If I am not able to fix it myself
    can you give me an estimate of how much it will take to get it
    fixed....again thank you so much for all your help!
    I am down in South Mississippi...I looked up the Flyback part it was around $65.00. Do I have to have a resister replaced too?
    Just been reading somethings...don't even know what that is..lol
    anyway...again thanks so much....
    Problem Solver:
  • 9 Answers
What is the Model#?
Posted on Jan 11, 2009
  • jpactech Jan 11, 2009
    solution are you gonna fix it yourself because it needs some tools for this, special tools solder anyway this is what it needs in order to resolve it...
    1-flyback transformer Part# (205064)
    2-TL010 is the location where this part at-(2SC5588)
    3-TL010 same as above-(part# 2599871)
    DC201(part#258740)
    which area a you at? Im in Indianapolis...parts cost around 150.00 roughly depend on the person who works on your set labour charge or home service charge....write me back
I have a rca model d52w20 52in rear projection with green screen the green tube has been replace and the board at the bottom of the tube has been replaced also and it still has green screen and a humming...
can you pull the green crt board and carefully check to see if the 200volt supply is present that one cause for over satuations of the crt if it is not there you need to trace back for the cause
Dec 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
Rca 52in rca hdtv
Hello lindseyskirk,
This is a common problem with this TV set as it uses the ITC222 chassis. The problem is usually localized to a group of capacitors
CP120, CP140, and CP150. If you have a background in electronics I can send you the schematics and you can unsolder them and replace them using the schematic to get the values from. If you do not have a background in electronics, I would suggest you have a qualified Television Technician do the replacement for you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52in HDTV will not stay on
I would turn the circuit board over and check for clod solder joints and cracked solder, you will have to look close, my other sugestion would be to get a can of freeze and spay the different IC's and see if it stays on longer.
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
