Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Was getting black alternating vertical lines about 2 inches wide
Tv had been repaired about 2 years ago for same problem they replaced pcb assembly now having same problem no picture
  • 133 Answers
It was probabily the Y-Sus board, that is what usually causes this broblem
Posted on Jan 11, 2009
Getting 3, 2" wide gray/black lines in screen.
Please answer the questions in video to yourself and then give a more detailed description, as there are many reasons depending on what exactly is happening. TV Repair Help for Vertical Horizontal Lines on Your TV Screen...
Nov 28, 2015 | Proscan 32LB30QD 32 in. LCD TV
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
Black line problems
Some components in the vertical deflection amp have been going out of spec with age.
The set may no longer be worth to spend money to service it because of its age. However, if you wanted to invest the money, the set is serviceable. Considering its age, the CRT may be soft, and there are many other older components that can soon fail.
I would be considering a new set.
Jerry G.
Apr 18, 2008 | Toshiba 36A40 36" TV
Vertical black lines on my Thomson 42" Plasma
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Sep 05, 2007 | Televison & Video
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
