Question about GE Profile Prodigy WPSE4200A
Agitator keeps coming off
After it spins out, it comes loose, I line it back up and snap it on, but it will not stay on.
  • 5,911 Answers
More than likely the plastic tabs that hold the agitator on are worn or bent to the point where they won't hold securely anymore. It's probably a good idea to go ahead and replace the agitator before it comes off during the wash cycle and damages the washtub.
Posted on Jun 07, 2007
Plastic agitator on bottom of drum keeps coming loose and doesn't stay in place ?
Pop off cap on agitator to expose drive shaft. See that the nut is tight orvthat it did not vibrate loose
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Jan 24, 2016 | Washing Machines
Agitation and spinning problem
get a new cap or try some sort of glue
Jun 28, 2010 | Washing Machines
Washer tub has come loose, it still agitates, its just way to loose
a washer tud is lose were when it go in to spin that help stay in balance
Apr 24, 2010 | GE WJSR2070B Top Load Washer
The drum won't spin or agitate the cause is the belt slipping off
There is a mechanical alignment problem beyond your ability to fix. Get a repair Tech and pay for a service call.
Oct 24, 2009 | Washing Machines
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
MAYTAG AGITATOR LOOSE
replace the agitator,if you look for a store that sells used machines you'll get the best price. Buy a used one!
May 26, 2008 | Maytag Performa PAV2200
Admiral Top Load Washing Machine
I had this recent, as well. The plastic grooves are wearing down, so there's nothing to hold it together with. I got some gorilla glue, and put the agitator back on the metal part that comes out of the motor. I let it set over night to dry. It's worked since I did it, and the agitator stays down...
Mar 18, 2008 | Admiral AW22 Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
75 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
