Question about Canon Office Equipment & Supplies
How to Print Legal size paper in Canon IR2420L
Whenever I try to take print of Legal size paper in Canon iR2420L from Bye Pass Tray, it shows "load correct paper". I always change the paper size to legal in Print option as well as Machine too.
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Posted on Jun 25, 2013
  • sk Enayat Ali Apr 27, 2014
    How to legal copy setting Canon ir2420l
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
MUKHTAR
  • 2017 Answers
SOURCE: print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Posted on Sep 08, 2009
SOURCE: won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Posted on Jan 07, 2009
  • 320 Answers
SOURCE: I cannot print to different size paper
you need to go to the printer set up on the desk top, there you can tell the printer what to do
Posted on Jan 14, 2009
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Cannot print Legal size on Canon IR2420L
LEGAL SIZE IS LGL THAT MEANING 8.5/14 INCH. IF YOU WANT TO PRINT CHECK THE SIZE OF THE PAPER, FLSC IS EQUAL TO 8.5/13
Apr 22, 2014 | Canon Office Equipment & Supplies
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Can't print proper legal size documents
please you aply the comand control p and you go the property select
and ok. you so the paper select and ok and you so the paper size
in select legal is ok and ok
and aply print legal size print ok
Sep 15, 2009 | HP LaserJet 1018 Printer
Showing change paper size when select LGL size paper in canon ir2016
If you are selecting legal on the screen to copy, then be sure that you have legal paper in the tray for printing and that any tray guides are properly set to reflect this.
Jul 22, 2009 | Canon Office Equipment & Supplies
Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
Jul 06, 2009 | Panasonic Workio DP-1820E Copier
Paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Minolta Magic Color 2300dl printer won't print legal size documen
Is tray one the bypass tray or a tray. check which one is tray 1
Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
1,042 people viewed this question
old marine
old marine
