Question about Whirlpool LER5636P Electric Dryer
Whirlpool LE5795XPNO 3-wire to 4-wire
I am trying to change a Whirlpool LE5795XPNO dryer from 3-wire to 4-wire. The 4-wire pigtail has red, white, green, and black wires. The Dryer has red, white, ground screw in unit with wire and green.
Help!
  • 5,911 Answers
The following link explains how to convert your dryer from 3-wire to 4-wire:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, or require further assistance, please let me know. I hope this helps you.
Posted on Jan 16, 2009
How to connect 4 wire pigtail to 3 wire dryer
connect directly to dryer. There should be a connecting block in back of dryer marked for blk.hot wire,white commen wire,and Green or bare ground wire & add another ground wire from a screw on dryer to green ground wire at the block.To be safe,check your owners manual. PS always be sure your pigtail is unpluged.first.
Sep 27, 2014 | Whirlpool GEW9250 Electric Dryer
Can you change a four prong pigtail with a three prong pigtail on a whirlpool duet dryer
Yes, you surely can!
Here's how.
When you open up the back of the machine where the electric cord attaches, you will see a row of 3 screws/bolts.
Your 4 wire cord has the black wire going to one of those screw/bolts. That is a HOT connection.
Your cord also has a red wire attached to a screw/bolt. It too is HOT.
These two hot connections are the outside two of the row of three screws/bolts.
The one in the middle is a ground wire, and is white.
The other, the fourth wire, usually blue or green, it is attached directly to the sheet metal of the dryer itself.
It too is ground..
Now, the 3 wire cord is not color coded, it is "position" coded.
The two outside wires go to the outside (in the row of 3) screw/bolts of the dryer. the middle wire is hooked to the middle ground screw.
It doesn't matter whether the outside wires go to the right screw or the left screw, but never to the middle screw.
By the same token, never hook the middle wire to an outside screw/bolt.
You will have no fourth wire going to the sheet metal.
Be blessed.
Apr 16, 2013 | Dryers
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Aug 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Need instructions on wiring for a 4-wire pigtail on a GE Dryer Just moved, the new place has the new 4 prong outlet so I replaced my pigtail with the new 4-wire one. Need wiring instruntions for the colors...
put the white in the middle,red on one side black on the other doesn't matter what side or just copy the old cord,now you need to ground it with the green wire,take off a screw on the back of the dryer near the other three and attach the green ground wire to it and screw it back in,the green wire just has to touch the metal frame to ground it
Mar 14, 2010 | GE Dryers
I have a 3 terminal electrical connector dryer and need to replace with a 4 terminal connector. I went to home depot and got a 4 terminal connector that has a balck,green,red,and white connector but when I...
The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green.
For safety's sake, put the Red on the right post, white in the middle, and black on the left. The green gets grounded right to the case.
Jan 02, 2010 | Dryers
I am in the process of trying to hook up a 3 prong electrical cord to a 4 prong but dont know which colored cords go where? any advice?
Get an qualified person to do it. If you do not have any idea how to do it, you are better off having someone else do it. If you have a 3 prong receptacle, you need a 3 prong pigtail. And if you have a 4 prong receptacle, the dryer needs a 4 prong pigtail. The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green. If you use a 3 prong pigtail, the center is the neutral (same as white on the 4 prong) and you will need the ground strap between the neutral (center) and the case. The wires do NOT cross over on a 3 prong pigtail.
Dec 31, 2009 | Maytag Dryers
3 prong to 4 prong where do you go with the ground wires
The following link explains how to correctly install a power cord on your appliance:
Read through the link thoroughly and let me know if you have any questions. I hope you find this helpful.
Jul 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Need to change dryer pigtail
3 wires, black and red goto either side, and the white goes to the center terminal , if you have a green(ground) that attaches on the body of unit itself
Dec 07, 2008 | Dryers
My mom has a 3 pigtail kenmore dryer her house has a 4 prong outlet we bought a new 4 pigtail cord how do you upgrade a 3 pigtail to a 4?
remove the old cord 3 wire, at the terminal block connect black wire onto the lefet screw, white onto the middle screw, red onto the right screew, and green to the frame of the dryer
Apr 10, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
209 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
