Question about Samsung Galaxy W 4g T679m Sgh-t679m Black Cat With Bow Cellphone Case Hard Cover
Samsung Galaxy w charging from mains power
The cell phone will only charge via usb on a computer and not through mains power
fossildude
  • 832 Answers
SOURCE: U600 Wont Charge
hey there! thanks for using Fixya.com!
If you drained the battery try to recharge again from your pc or laptop, I am sure that there is nothing wrong happened when you left your mobile phone connected with your pc. You PC is off, so there is no power supply that will flow to your mobile or charger. It make sense that it just drained. Try to buy a new battery and test it, let's see if your mobile will work again, if you don't want to buy a new battery to waste some penny. Just bring your phone to your nearest technical shop to test it. I guess they will not charge you for that.
Cheers! thanks! don't forget to mark!
Posted on Feb 17, 2009
misskittyfoo
  • 20 Answers
SOURCE: Charging battery of a Samsung U600 phone
I charge my phone (which is a Motorola) all the time with the USB cord. If you have the driver for your phone installed on your computer, it should work =)
Posted on May 28, 2009
  • 13 Answers
SOURCE: Samsung galaxy tab will not
For most android platform products when you have "Mass Storage" turned on it wont charge. Its possible that the Car-USB charger isn't putting out enough juice to charge it in its on state. Could be to the quality of the car charger or that the car is already under strain from say a stereo or other devices being charged.
Posted on May 04, 2011
Geekman
  • 32281 Answers
SOURCE: my samsung galaxy pro GT-B7510 battery Not getting charged by Charger and only by USB cable and power lossing immediately i remove cable, how can i solve ??
Check the mains power adapter with a multimeter. Plug the adapter into the wall mains socket and then measure the voltage on the adapter plug, the voltage should be slightly higher than the voltage that is printed on the adapter. If you get a low reading or zero reading the the charging adapter is faulty and needs to be replaced.
Posted on Mar 30, 2012
  • 547 Answers
SOURCE: samsung galaxy fit mobile not charging even port was changed
maybe charging port was not properly changed, make sure about this and also about charging ic is not water damage.
Posted on Jun 29, 2012
How to connect samsung galaxy j2 to computer
use the charge lead to connect the usb to the computer port
Mar 30, 2017 | Samsung Cell Phones
How to screenshot
How do I take screenshots on my Samsung Galaxy Avant ™ ?
www.samsung.com > ... > Cell Phones > T-Mobile
Samsung Electronics... of the screen. The screenshot will be copied to the clipboard and saved to the Screenshots folder in the Gallery. ... Print: Print the screenshot to an available printer via a wireless network, Wi-Fi Direct, or USB cable. Settings: ... Cell Phones.
How to take a screenshot on Samsung Galaxy - PC Advisor
www.pcadvisor.co.uk > ... > How to take a screenshot on Samsung Galaxy
May 15, 2015 - Taking a screenshot on a Samsung Galaxy smartphone is a simple task, but it's a ... Whether you've got a Samsung Galaxy S3, Samsung Galaxy S4 orSamsung ... How to take a screenshot on Samsung Galaxy. PC Advisor · Phones ....Once my Galaxy S3 get fully charged on wireless charging pad , I will ...
How to take a screenshot on Android phones, tablets - PC ...
www.pcadvisor.co.uk/.../how-take-screenshot-on-android-phones-tablets...
Aug 20, 2015 - In the early days of Android taking a screenshot on a phone or tablet ... on an Android smartphone or tablet, including the Samsung Galaxy S6, ...
Dec 21, 2015 | Samsung Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Samsung galaxy nexus no charge
Hello My Dear Good Morning:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 23, 2012 | Cell Phones
Samsung galaxy s not charging
First Option:
Second Option:
Nov 02, 2012 | Samsung Galaxy S I9000 (8 GB) Cell Phone
My samsung galaxy pro GT-B7510 battery Not getting charged by Charger and only by USB cable and power lossing immediately i remove cable, how can i solve ??
Mar 29, 2012 | Samsung Cell Phones
Not charging from mains
my samsung g 600 is not charging i think this is short please help me with diagram
May 25, 2009 | Samsung SGH-G600 Cellular Phone
Samsung Galaxy W 4g T679m Sgh-t679m Black Cat With Bow Cellphone Case Hard Cover Logo
176 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
