Question about Compaq Keyboard
Does apple A1243 have backlight? how do I turn it on?
It is at work so...who knows if it even has backlighting
How do I change the backlight setting?
How to adjust the backlight strength, time-out length of the ...
www.cnet.com > Mobile > Wearable Tech
CNETJul 23, 2015 - In order to adjust either setting, your Pebble Time watch will need to be updated to version 3.2. Launch the Pebble Time app on your device ...
how do i adjust backlight time on my iphone ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Nov 18, 2012 - Not sure what you mean by Backlight time. But you can adjust how long it is before your phone auto locks at. Settings> General > Autolock. How do in change my backlight settings on my iP...
Dec 31, 2013
Did they do away with the backlight timer for i...
Nov 6, 2011
how do change the back light to time out?
Jan 14, 2009
More results from discussions.apple.com
Dec 25, 2015 | Watches
Backlight on ipad not working
Sounds like the backlight is turned all the way down. Did you try to restart (or even reset: Hold down the Sleep/Wake button and the Home button simultaneously for 10+ seconds, this will cause a reset)? If this don't work, it may be a hardware problem, and a visit to the Apple Store may be a good idea.
Good luck! :)
Apr 14, 2014 | Apple Tablets & eReaders
Iphone screen backlight not working. What to do?
If the backlight on your Iphone is dead, you need to replace it. This does usually happen if it received a sharp drop or exposed to liquid.
Check out the following link for your repair options
Repair Backlight on Iphone 3g
Jan 09, 2010 | Apple iPhone Smartphone
My backlight won't turn off on my iphone s
check options turn off light in menu
Dec 05, 2009 | Apple iPhone Smartphone
Backlight is not working
eht coil generator which generates power for backlight tube is damaged change it
Nov 26, 2009 | Apple Cinema Display 23" HD Monitor
Backlight on a 2nd gen 32 gig ipod touch
http://www.fixya.com/support/r3771170-phone_water_damage
Jul 13, 2009 | Apple iPod touch
My 1st gen ipod touch backlight doesn't turn on. I tried to turn my lightness up but still their is not light. the ipod works great though but the light doesnt work
i don't know if this will work for you. I had the same problem with mine and i read somewhere that u need to either blow really hard in the bottom where you connect the sync cable or use a can of compressed air and it will clear dust off the place where the brightness is hooked up to the motherboard. After blowing put iPod in sleep mode for about 5 minutes and then turn back on. If there is no light then go to settings>backlight and then make it go all the way up. Might Work
Jun 23, 2009 | Apple iPod touch
Frozen nothing works!!!
Press the Menu Button and the Center button until the apple appears and it will reboot
Dec 25, 2008 | Apple iPod Photo MP3 Player
Ipod backlight wont work
Most of the time this is the LCD panel itself - it has built in LEDs around the edges of the screen that light it up. A simple swap out of the LCD is what will solve this. Email me if you need this done.
All the best
Sean
PiDigital
Dec 14, 2008 | Apple iPod nano
30k gb bla
iPod has backlighting, so you can see the display in low light.
You can configure iPod so the backlight turns on for a set amount of time when you press a button or move the scroll wheel.
To access the backlight settings:
  1. Select Settings > Backlight Timer.
  2. Select a setting from the menu. Options include having the backlight timer:
    • Off
    • Turn off after a period of time between 2 and 20 seconds
    • Always on
A backlight on/off switch can be added to the Main menu by selecting:
Settings > Main Menu > Backlight
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
Compaq Keyboard Logo
102 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
