Question about Gateway Computers & Internet
I have a emachine desk top with an 3 front panel wiring going to a gateway motherboard hhd led / pw rled /power sw trying to find out where they go on the panel 16 header gateway motherboard e4100 trying to reconnect them because my power botton was acting up
2 Suggested Answers
  • 570 Answers
SOURCE: Need to reconnect (Power LED, Power SW, H.H.D LED)
Here is the diagram for your connection. It may vary but most probably there are names are written on the mother board for the connections
Thanks.
Posted on Oct 22, 2010
Gateway MB.SD101.001 Pitbull Motherboard
The motherboards are almost always labeled and so are the wires. Colored wires are + and black is -. The LED wires and power button wires can go on either way. HDD LED, PW LED PW SW is the switch. These are very common abbreviations on the motherboard.
http://www.intel.com/support/motherboards/desktop/sb/cs-009016.htm
Take a decent picture of your mobo pins and I can probably tell you where everything goes.
Jan 28, 2013 | Computers & Internet
Gateway 500GR Mother board Connector S Wiring
You are correct so far.
This is a perfect example of using deductive reasoning based on intelligent thought.
'Armed' with that I can see you will go far in life.
Gateway Support > Gateway 500GR Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/3724/3724nv.shtml
Click on Components in the list.
Scroll down. Under the bold black heading - Motherboards - click on
102007 - Intel (Augsburg) No CPU Motherboard R0
Click on Specifications.
Chipset: Intel 915G Chipset
http://www.ascendtech.us/gateway-augsburg-intel-915g-motherboard_i_mb4gwaugsburg.aspx
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
In the photo the Front Panel header is marked by the letter S.
Let's go to Intel Support, and download the Product Guide for an Intel D915GAV motherboard,
http://www.intel.com/support/motherboards/desktop/sb/CS-012048.htm
Click on the blue -
Intel Desktop Board D915GAV Product Guide - (English) PDF
Scroll your mouse cursor to the bottom/middle of the page, to bring the 'ghosted out' navigation guide into view.
Click on the Adobe PDF icon to the far right.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" is briefly shown)
Different design motherboard in the layout of certain headers, and connectors, but same Ol' Front Panel header pinout, Intel uses for 10 pin Front Panel header's.
Whether it is an Intel O.E.M. motherboard, or one they made for a pre-built computer manufacturer.
Front Panel header for Gateway 500GR, is next to the bottom edge of the motherboard, and all the way towards the right.
5 pins across the Top row, 4 pins across the bottom row.
Pins on the Top row are numbered ODD.
Pins on the Bottom row are numbered EVEN.
TOP row; Starting on the RIGHT side going towards the Left;
Pins 1, 3, 5, 7, and 9.
BOTTOM row; Starting on the Right side going towards the Left;
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. No Connection. Pin reserved for the factory.
(5 Volts DC)
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No pin 10.
Regards,
joecoolvette
Aug 21, 2012 | Gateway Computers & Internet
I'm working on an Emachines T3624 I took out the front panel connectors and I can't remember where the power switch connects to the motherboard. I know the general area but I don't know the exact spot....
The manual can be downloaded here, just click on "drivers and downloads" and follow it out.
http://support.gateway.com/us/en/emac/default.aspx
I was hoping to refer you to the manual to provide a diagram, but the manual does not show the front panel I/O connections, so I'll give you general instructions.
The front panel header is a set of two rows of pins. You may need a magnifying glass and flashlight to see the small print on the motherboard that identifies the pins. Look at your front panel cables and look for the same abbreviations on the circuit board. You should see "pw sw" (power switch), "rst" (reset), HDD (hard drive activity indicator LED), and "pw" (indicator LED that shows that the computer is powered up. There should also be speaker.
Just match the cables to the pins on the motherboard. Polarity ( + or - ) is only important for the LED's ( pw and HDD ) Don't worry, if you connect them wrong, they just won't work, just swap wires.
Apr 29, 2011 | E-Machines T3624 PC Desktop
My Emachine T 3626 i got new motherboard, new power supply.new cpu fan and now is not working , i conect everthing but the power lec and power sw dont come out the only way is to turn oof from the...
1) The eMachines T3626 uses an ESC MCP61SM-GM motherboard,
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtml
Click on > Product Views
Now click on > P- Front Panel Connector
http://support.gateway.com/s/MOTHERBD/Shared/4006233R/4006233Rmvr18.shtml
Did you connect the cables, (Wires), from the Front Panel to the Front Panel Connector, correctly?
Looking at the Front Panel Connector, observe where it has > 2, at the bottom.
(Right above the small round object with the Orange dot in it)
This is the Bottom of the Front Panel Connector
The pins are in Two columns.
The column on the Right side is numbered > Even
The column on the Left side is numbered > Odd
Starting at the Bottom going Up on the Right side,
Starting at the Bottom going Up on the Ledt side,
Pins 2, 4, 6, 8, and there is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive Activity LED light
B) Pins 5 and 7 are for the Reset switch. (IF one is used)
C) Pin 9 is for the 5+ power
D) Pins 2 and 4 are for the Power On LED light
F) There is NO Pin 10
Let me know in a Comment.
Dec 01, 2010 | E-Machines eMachines Desktop PC
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
Need to reconnect (Power LED, Power SW, H.H.D LED) wires for eMachines MotherBoard D33007 VG33
Thanks.
Oct 22, 2010 | Gateway Computers & Internet
Had to replace power switch on emachine computer need to know where wires go
You must check cable(small) one the (left or right) one hard drive, CD Drive, floppy disk and for motherboard (the big one) .You check the manuals, is not hard just follow where the power lines.
Feb 21, 2010 | E-Machines eMachines T3830 PC Desktop
Need where pwr sw and pwr led and hdd led plug onto au31 motherboard
Here is a link for the manual for your au31 motherboard. The diagram explaining the front panel headers is on page 12.
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
Dec 02, 2009 | E-Machines T3092 PC Desktop
IBM Netvista MB 49p1599 Front Panel Pinout
1 pw sw
2 pw sw
3 rst
4 rst
5 - pw led
6+ pw led
7+ hdd led
8 - hdd led
<== left 1. . . . . .8
ATX connector ==> right
Mar 07, 2009 | IBM (49P1599) Motherboard
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
