Gfi outlet trips right before the final spin cycle. This is on a top load kenmore 80 series washer. I replaced the timer but the problem still exists. The timer seems to be in a pause mode. In other words, the motor is not yet under power. Any ideas here?
  • gregg dawson Nov 30, 2012
    murray, Thankyou for the suggestion. let me first add that this is a new problem. the washer has run fine on this gfi circuit for a few years, until now. also, the timer is in pause mode with no power to the motor. I just thought of a possible problem though. Im now thinking I need to check the lid switch. Maybe a shirt circuit there. It does make sense now, The timer is about at the mode that switches the circuit that has to be closed before the spin cycle actually begins. Thanks for the help. I will certainly look forward to additional input.
    Problem Solver:
  • 8 Answers
Motor driven appliances can trip GFI outlets when there is no problem at all with the appliance. When a large motor first starts, it draws more current for a short time and some GFI outlets will trip (others may not).
Are GFI outlets required by code in your state/county for washing machines? If not, replace the GFI with a standard outlet. If so, replace GFI with a higher quality GFI outlet.
Posted on Nov 30, 2012
larryyb
  • 291 Answers
SOURCE: Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Posted on Nov 25, 2008
mobilityGo
  • 68 Answers
SOURCE: My Kenmore top loading, series 80 washer seems to
check the rubber feet and does it rock when it not on ! we have had the feet worn
Posted on Jan 12, 2010
  • 714 Answers
SOURCE: Kenmore 80 series top load washer. Will work on
if that arm is white and inside your clutch assy,that is the brake release arm that releases the brake to allow the basket to spin. it has 2 little fingers on it that lineup on the brake release cam, also check the bottom of yuor basket drive tube see if it has worn down or if the clip is there that holds that arm in place
Posted on Feb 21, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore 80
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a top loading Kenmore 80 series washer that...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Oct 01, 2010
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
No rinse, no spin kenmore series 80
need to see if your timer is not advancing to next cycle. if not then replace timer
Jun 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer dead
ck to see if you here a lid switch click when lid is slowly closed if not suspect lid switch may be on right sidew of opening or under left rear of lid at hinge also ck for loose lid hinge screws left side first
Sep 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
