Question about Samsung RB2155SH Bottom Freezer Refrigerator
The fridge has a short - Samsung RB2155SH Bottom Freezer Refrigerator
  • Samsung Master
  • 4,654 Answers
And your question is? Are you asking for assistance to solve a short circuit problem? What happens to the refrigerator when you say Fridge has a short? Cooling? Fans Run along with compressor? Sea Breeze
Posted on Nov 30, 2012
Errorcode EE in display. Whats wrong?
E1 - Freezer thermistor open circuit.
E2 - Freezer thermistor short circuit.
E3 - Fridge thermistor open circuit.
E4 - Fridge thermistor short circuit.
E7 - Evaporator thermistor open circuit.
E8 - Evaporator thermistor short circuit.
E9 - Temperature set switch open circuit
EA - No feedback from Baffle
EB - Fridge Baffle motor operating continuously
EE - Defrost time out
This was the only code listing with an EE error code - which is a Hotpoint - so if your's isn't a Hotpoint it is probably incorrect.
If you do have a Hotpoint Refrigerator then either the defrost timer is not functioning correctly or your heater element is malfunctioning.
Jun 20, 2011 | Refrigerators
The fridge shut off and tripped the breaker, tried to reset breaker and it tripped again. I unplugged fridge, breaker was able to reset, voltage good at outlet, ohmed out fridge plug, appears to have a...
Could be anything, bad cord or plug, possible bad appliance bulb causing short (had that happen on another appliance) or the main problem, bad compressor.
Sep 05, 2010 | Refrigerators
Fridge short circuits power after a period of time
it needs a new defrost heater , can b a bit tricky to change
Jan 31, 2010 | Refrigerators
Fridge cools short time and stops
sounds like the condensor fan isnt running. I would replace the fan if thats the case. If the fan is running then you have a overload problem or a bad compressor
Aug 02, 2009 | Refrigerators
Fridge got wet, now it sparks and shorts power
I suggest you unplug the fridge. If possible you can then open the wiring connection cover on the compressor (where the supply cable connects) and check what is causing the short circuit. Probably when moist there was a short circuit due to water but this may have burned some of the wiring. This will be quite visible and easy to repair with a bit of insulation tape.
Apr 15, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Fridge shorts power out
From your description it sounds like a short in the defrost heater circuit. It would normally be a repairable item. You may want to consider the age of the refrigerator before getting into the repairs.
Aug 24, 2008 | Refrigerators
Bosch Fridge Freezer KGV2604G (9 years old) , compressor does not kick when Fridge warms up. Fridge has to be turned off, left for a while, then truned on before the compressor starts to work and cool the...
See here for how to fix: http://www.howtomendit.com/answers.php?id=17078
(Scroll to bottom. I just use a piece of insulated wire to create the short.)
Jul 22, 2008 | Refrigerators
Fridge problem
You may have a short some where in the fridge. If you have a multimeter, I would suggest metering the power leads to the compressor. The compressor may be bad, if you find no shorts in the metering of the power leads.
Jan 10, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
168 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
