Question about Dryers
How to remove front cover from maytag model mgd577otqo?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here are some videos that may help you.
Posted on Nov 30, 2012
Need to replace orfices cant figure out how to get cover off to get to valve
You don't give model #. Most Maytags have 2 screws at bottom of front panel. Remove and swing panel forward from the bottom. Some Maytags require removing the front panel (2 or 4 screws around the door opening). Slide and pull front panel off.
Oct 23, 2013 | Maytag Dryers
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
Dryer not rotating.
you need to remove the front cover either by removing 2 screws at the lower edge of the front panel,if no screws on this model,then take a putty knife or flat blade and at the top of the front cover between the front and top cover insert it at the edges about 2 inches in and pop the retainer clips inside the panel,then swing it out and remove it,then remove the top cover and then you can access the belt
May 24, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag A712 washer. Water pours out.
Maytags last great washer! This model was top of the line from 1985-1988
The leak can be coming from many different places. Pull the front cover off and we'll go from there. To remove the front cover, loosen and remove 2 phillps screws near the bottom of the front cover. Lift the cover at a 90 degree angle and the cover will pull off.
Sep 29, 2009 | Maytag Washing Machines
Model A 512 washer-water pours out from plastic unit on hose at top left after relay water line unit
Sounds like you need a new injector.
Remove the front cover (loosen the 2 Philips screws near the bottom, lift the front cover 90 degrees and pull back). Remove 2 bolts at each corner from to the top cover located up front. Remove the beach dispenser hose, tilt top cover up. The injector will be on the left.
How do i open the front of my dryer to clean out dust and lint
depending on the maytag model the bottom of the front cover should have 2 or3 screws by the floor,remove these and cover should hinge upward and top part of frt cover has clips,they secure it this way for cosmetic reasons so fasteners do not show,look carefully they hide em...good luck
Aug 18, 2009 | Maytag Dryers
Dryers Logo
Top Dryers Experts
