Wen i start my pc then my motherboard dnt wana show video on my scren.hw can i fix this problem on my motherboard.and here on my motherboard is a P9 plug in but my power supply dnt have that plug is it needed
  • 2,878 Answers
P1, P2, P3.... are just spare power connections from the power supply. Some units are not even labeled, because it does not matter which one you use as long as they fit. If this is what you are referring to.
Posted on Nov 30, 2012
vincent721
  • 240 Answers
SOURCE: i put my 3 0 ghz cpu in my Gateway Intel 850
verify your manufacturer if the board is capable for CPU upgrade for the CPU you install.
chipset and CPU must be compatible in order to work..
even it power up..but still there is a conflict in BIOS (basic input/output system)
Posted on Mar 16, 2009
Ownij
  • 67 Answers
SOURCE: pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
  • 256 Answers
SOURCE: needing to plug new power source to motherboard, need the diagram format
There are only 1 or 2 power supply connections to motherboards. On single (older) connection motherboards, it is a 10 pair Connector.On doule connection MB there is the 10 pair and a 2 pair connector.You really can't miss where they go. A 2 connector power supply will work on a 1connector MB. The rest of the power supply connectors are for disk drives. The big flat 4 connectors are for hard drives and CD/DVD drives. The small flat 4 connectors are for floppy drives.If you take the old PS out, you will see where to put the new PS in. Hope this helps.
Posted on May 29, 2009
herodog909
  • 98 Answers
SOURCE: replace atx 250 12e power supply with 350watt power supply per
Sounds like there maybe some kind of problem with *********** board connector. Double check that it is the right size, and be sure there are no places that still need power. When you get the chance I'd check the following:
Disc Drives
Motherboard
Floppy
Hard Drives
That all cards are secure, if there are any loose connectors your comp will declare "short circuit". At that point, unplug the cord from the mother board (the power cable) and try again.
Any USB Cables
Anything that looks loose, and finally, recheck the compatibility with your system.
Good Luck!!!
Posted on Jun 02, 2009
SOURCE: Hi, my HP Pavillion a1240n
There are only certain items that will not power up a machine. 1. The power supply itself could be gone. 2. Check your ram. 3. Your hard drive. In most cases it is the power supply. Take out the power supply from the machine and plug it in to a wall socket. If it starts that it is not the power supply. If it doesn't start replace the power supply.
Posted on Dec 05, 2010
Dell Dimension 2400 PC Desktop how to wire
Industry standard PC, XT, AT, and LPX motherboards use the same type of main power supply connectors. They use two main power connectors: P8 and P9. Each of the P8 and P9 connectors has 6 pins that connect power supply to the motherboard.
May 29, 2014 | Dell Dimension 2400 PC Desktop
When do you insert the diagnostic post card test in the BIOSTAR motherboard computer and start the POST the post card test showed P9; what thats mean ?
Post card testers usually go into the PCI slot. You will need to read the post card tester manual to determine what F9 means.
Jun 10, 2012 | Computers & Internet
Wen i turn it on the scren will not come on
It could be one of three things. The monitor itself, the cable (not very common), or the video card. Now if the video is onboard ( part of the motherboard), just getting a graphics card will get it back up and running. Now depending on the slots in your computer it will need an AGP, PCI, or PCIe video card.
Jun 28, 2011 | Computers & Internet
Speakes dnt work on the rh side wen putin cd on wen putin aux in dnt work on the lh side wen radio on they all work
check the connection to the speakers at the speaker otherwise you may need a new sound card in the computer itself...
Feb 13, 2011 | Audio Players & Recorders
Dnt knw hw 2 lock d phne for security purposes
Protect your private photos, voice and sound files, videos, confidential documents - just any kind of files on your Nokia 6110 Navigator! Has a desktop companion.
it's a cool software Best crypto
http://www.smartphoneware.com/download/crypto_wm/best_crypto_v2_00_wm.cab
or
http://www.fileden.com/files/2008/10/14/2142396/FileLock.jar
Aug 23, 2009 | Nokia 6110 Navigator Cell Phone
Boss chaos 150 200 watt that shows light but doesn't produce sound
DID YOU CONNECT THE JACKS FROM THE HEAD UNIT? JUST A THOUGHT AS THIS IS EASY TO OVER LOOK
May 27, 2009 | Boss C150 Car Audio Amplifier
No sound coming from my laptop
HI, i recommend re installing all the sound drivers in this unit. the base sound files are corrupt. this will fix this issue.
May 21, 2009 | Emagic EMI 6|2m External Sound System
Hiii
You have a video driver conflict
Check which video card is in your computer.
Use pc wizard (download) install check which driver you need name and number
EG cmedia 2341 Drivers type into search bar and download correct driver
Jul 26, 2008 | Asrock 775i65G Motherboard
PC Restarts
check for the BIOS battery voltage! it should be 3 volts. if not, replace it!
Nov 16, 2007 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
