Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
Sony Bravia kdl46x3100
Does not turn on green button flash
5 Suggested Answers
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
SOURCE: sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Posted on Jul 12, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Posted on Oct 09, 2009
yourstupid
  • 4 Answers
SOURCE: the standby button is flashing twice- sony bravia klv-40v550a
Unplug the power cord for 30 min, plug back in and turn on.
Should ths not work seek repair or replacement
Posted on Apr 10, 2010
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.For printer
    Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
    When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
    try this. It is the reset for the waste ink error (8 flashes)
    1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
    power button.)
    2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
    release the Resume button and Power button.
    3) The green indicator flashes during initialization.
    When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
    (The indicator toggles between orange and green each time the Resume button is pressed.)
    4) Next, press the Power button, and the green indicator will light, and the function will be executed.
    5) Turn off the printer then back on and error should clear.
    Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
    Flashing green button
    Where are you located? If you don't want this Sharp 35VX-H2000 anymore, I will take it, even if it's broken. Thanks.
    Jun 29, 2010 | Sharp 35VX-H2000 35 in. TV/VCR Combo
    Five flashes of orange followed by one green flesh
    1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
    8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
    Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    Jan 02, 2010 | Canon BubbleJet i9950 InkJet Photo Printer
    My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
    1. Turn off printer
    All the best Pineworks
    May 15, 2009 | Canon S400 InkJet Printer
    Cannon pixma ip1700 not printing
    1. Turn off printer
    Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    S9000 printer will not print.
    Hi
    Try this see if work for you.
    Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
    1. Turn off printer
    Jan 13, 2009 | Canon i950 InkJet Photo Printer
    Flashing lights
    Canon IP 2000 / reset
    1. Turn off printer
    8. Your printer should respond as normal..
    Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
    Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
    69 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
