LG LSL 122V-3
Heat transfer from hardware to air does not happen
Is my portable lg air conditioner suppose to be blowing hot air out of the back
YES
it works the same as any air conditioner where if you go outside and place your hand at the fan then it will be blowing hot air
In the instructions it should say place the rear near an open door or window or use the hoses to move the hot air out of the room
air conditioner units are basic heat transfer units where they take the heat out of the room and transfer it to the outside and in the process remove the moisture from the air in the room which i turn makes it more comfortable
Mar 14, 2016 | LG Heating & Cooling
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
Have a LG Split -can't get it to heat. Air conditioner works fine, when I set the remote to heat all that happens is the blower works.
If it does not start heating after a couple of mins check change over valve and coil located in condensing unit if it's stuck on cooling sometimes you can tap it to free it but if it is sticking it will need replaced
Nov 23, 2011 | LG Heating & Cooling
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
I am having problems with my windows 98 LSl.com
Remove this line from autoexec.bat :
C:\Windows\odihlp.exe ( or whatever your path is )
Nov 15, 2009 | Microsoft Windows 98 for PC
Xbox 360 overheats on startup
there could be hardware problems! mine never gave the two lights when it started it but when playing certain games it overheated and thats whats happening.. i got upset and opened mine up[ voids warrenty for three red lights] and added a 3 inch fan with a 12 v converter for its on power. i set it in on the heat sink and the bottom right corner of the xbox..
so i think you should get a powerful 3inch by 3inch fan with its on power supply and set ur xbox so you can point the fan at the bottom of the xbox! this will help! dont open ur xbox just set a powerful fan[ radio shack, walmart, hardware store] and let it cool the bottom of ur xbox!!!!!!!!
Cheapist way
!!items needed!!!
1. 12 v dc brushless fan
1. 12 volt ac power adapter that hooks up to the wall and the fan for a Direct Current!
thats it may cost over 20 and walmart is cheap and a little less quality
but as long as air pushing on the bottom of ur xbox is moving fast[ dont put the fan to close] so heat is transfered ur good
Jun 19, 2009 | Microsoft Xbox 360 Console
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
