Acer timelinex 5830t laptop batterij
The problem is that i have a Acer timelinex 5830t laptop whose 9 cell original dell battery which is few days more than 1 year has started to behave real awkward,the battery is like that: http://www.accukorting.com/acer-aspire-timelinex-5830t.html . When i put on the charger it charges the battery upto a certain level and then the battery led signal above keyboard starts to glow 4 times red and one time white and the status says under temporary failure mode. After I remove the charger and wait for 10 min approx the battery comes under normal condition. The main problem is this level until it charges is decreasing and has come down to 73 % now. I'm trying to find a way to troubleshoot the problem without having to buy a new battery or laptop.What should i do?
  • 32,281 Answers
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Nov 30, 2012
coolcat_12
  • 259 Answers
SOURCE: Acer Aspire 3690 won't power up
I can only see first two lines of your message so might need more information ALL computer power off if the not used for sometime this can be 5 mins or 5 hrs depending what your power functions are set at If it is not plug into the wall plug in and leave for half an hour then try turning on and in control panel the is an icon called power change the setting to suit
Posted on Jan 23, 2009
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
portland1970
  • 145 Answers
SOURCE: Hello, I have an Acer aspire 5741. Just got it
contact your ceo contact again and make them fix...their problem...your acer is junk and they need to replace it
Posted on Jan 28, 2011
Nemesis5791
  • 133 Answers
SOURCE: why my acer 4741G battery
Typical behavior of a faulty battery, cells are not accepting full charge... If its still under warranty, you can get the battery replaced no charge, otherwise you're in to fork out over 100 USD for a new battery pack.
Posted on Aug 20, 2011
SOURCE: Acer 8920 G restarts after 3 min and again shuts down
First make sure your fan is operating on your processor it takes about 3 mins for it to over heat and stop and shut itself down for safety to prevent burning up the processor.if its not this read on.
Also when you boot into safe mode then do a system restore to a date before the problem started. But first in safe mode run your antivirus scan to find something that is missed while being hid behind the operating system while functioning. Remember to rate my solution and leave testimonial this is how i earn my achievements here on FixYa thanks in advance
Posted on Apr 28, 2012
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Removing battery acer timeline
Depends on the laptop model, some of them have a lock that you have to press, some have multiple switches.
There is two small switches on the bottom, opposite sides of the battery. One you have to toggle and the other just hold while remove the battery.(But it depends on the model...)
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Apr 03, 2013 | Acer Aspire TimelineX 5820T-5951 Notebook
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
What's your problem?Hello, I have upgrade my laptop battery to a 12 cell battrey. the instructions that came with the battrey say that it requiers bios update in order to work in my acer aspire la
One last note:
I did find a 9 cell upgrade battery that will work.
Battery - 9 cells 7800 mAh, 11.1 V Part # LB-AC20-07800-01
from http://www.laptopbatteryone.com/
Acer Aspire 5735z. I am running.. OS Windows 7-32 bit & bios V1.08
Dennis
Jul 24, 2012 | Acer Aspire Computers & Internet
I can not power on my acer timeline x 5820t. No power at all. Had this issue before and after two days all of a sudden the laptop pwer switch worked again. Now no power again. Tried without battery and...
Then your motherboard is problem, so take the motherboard to refix.
Note: Pin board can be refix (work on), while pinless board cannot not be repair.
Best regards.
Jun 28, 2011 | Acer Aspire TimelineX 5820T-5951 Notebook
I forgot the password for bios.Can you tell me please how can I restart my computer? Acer Aspire TimelineX 5820T
Most of the time the bios password can be reset by simply pulling the CMOS battery out of the motherboard. The CMOS battery is the little watch battery the resides on the motherboard.
Beings that its a laptop, it may be harder to get to it. Try looking in the manual on how to get to the battery, this should provide all the information you need. If you need more help please reply and i will do my best to help.
Mar 28, 2011 | Acer Aspire TimelineX 5820T-5951 Notebook
Mijn batterij knippert rood de batterijtest branden eerst 3 ledjes knipperen en daarna alle ledjes constant, is de batterij nu goed of slecht en start daarom de laptop niet op ?
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
Hope this helps.
Jan 01, 2011 | Dell Latitude D610 Notebook
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
