Question about Evenflo Aura Traditions Travel System Safari Trek Stroller
Shoulder strap adjustment on baby car seat
I cannot figure out how to get the belts free to slide them through the small slot from the back of the seat to the front.
3 Suggested Answers
  • 135 Answers
SOURCE: shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: Evenflo ParentLink Department: 1-800-233-5921
Posted on Mar 31, 2007
The straps are removed through the back - they are difficult to remove. Turn the clip in the rear of the seat, and puch through the opening. This will allow you to then place the straps at the correct position. Once they have been adjusted, then just push the clip back into the rear of the seat, and push down to lock in place. To adjust the width, just push down on the upper clip on the top of rear of the seat, and either tighten or loosen.
Posted on May 12, 2007
Need to remove the cover from a britax eclipse
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
I have a Safety 1st baby carseat, it's a 22-391-MLO. I need to know how to put the straps back in!
each end of the long strap should be threaded up through the slots on either side of the baby's bottom, and then through the diagonal slots even with baby's shoulders. There is a clasp on the back of the car seat that you can thread each end through and adjust to the proper length.
Jul 10, 2009 | Britax Eclipse Si - Paris Convertible Car...
Car seat adjustment for britax eclipse
Tilt seat back and slacken straps fully. Follow each shoulder strap through back of seat and down towards lower back of seat. There you will find (maybe hiding under a plastic cover) a metal bracket that retains the straps. You can slide the straps out of this, pull out and thread back through at a higher point.
The actual tension adjust ment is usually a metal clip that you push or pull which is located in the centre/ front are of the seat, or front/centre, underneath where the child's feet hang.
Apr 05, 2009 | Britax Eclipse Si - Paris Convertible Car...
Having trouble with straps in car seat
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps.
Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat.
The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it
doesn't twist, either.
There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.)
One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Dec 30, 2008 | Cosco Juvenile Scenera Convertible Car...
I have a 02-442-PRI 11-17-98 Cosco
If you washed the straps, they will need to be replaced. Lock the harness together, to prevent the straps from being twisted. Feed the top part of the harness through the slots that are AT or ABOVE your hangchilds shoulder if the seat is forward facing. IF the seat is for rearfacing, feed the top part of the harness straps through the shoulder slots at or BELOW the child's shoulder. Once each is through, reach down and attach them to the silver plate that hangs from the **** strap adjuster. Once you silde each of the harness straps, then slide the bottom of the through the hole in the cover, then into the base of the seat, folding the top like a triangle makes it easier to get through the tight holes. Repeat on the other side and you are ready to travel! Thanks!
Jun 16, 2008 | Cosco High Back Booster 22-200 /22-207
Manual for a car seat
First set the harness together at the chest clip and the **** buckle. Then slide each shoulder strap through at the best height for your child. For a forward facing seat , it should be at or above the shoulders. Once both shoulders are passed through, there is a Tshapped metal flat piece, each belt slides onto that. That is 2 of the 4 ends of the straps squared away. The bottom 2 , you slide through the holes in the car seat, through the holes in the shell of the seat, and then pull to ensure they are in tight. Thank you!
Jun 15, 2008 | Graco Baby Gear
Car seat trouble
Where is the button to release the shoulder straps for a comfortable fit or model # 8465HGA
Dec 03, 2007 | Graco SnugRide - Giselle Infant Car Seat
Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
May 29, 2007 | Evenflo Victory 5 Comfort Touch
Shoulder straps
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Evenflo Aura Traditions Travel System Safari Trek Stroller Logo
285 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
