Question about Xitel INport (HFLI1X1) Audio Input
Levels indicate input but no red/green bars and no playback
Windows xp - not recording evidently but shows input
Fed directly out of the tape deck -
Posted on Jan 11, 2009
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
With adobe audition 1.5 how do i get my voice to play back through edit view? Ive really been up all night trying to figure this problem out someone please explain step y step
First, be sure you see the audio track on "edit view". It shows the peak of the recording level. If it is a straight line, you have not recorded your voice. If the recording is there, you have to be sure your computer audio is set to play back through the speakers. If the recording is not there you have to set the computer to record from your input, either line or mic input. Set the level to the max. When you record you can see the input level on the two bars at the bottom of the screen. Double click on them to see the input level before you start recording. You want the level to be near "zero", at the far right. If the level is above "0" the peak indicators will turn red. You don't want red lights. Set the input level just below the red peak. Click on the red record button at the panel on the lower left of the screen. When you click the record button you may see a pop up that want you to set the recording parameters of the file. You have to make these selections before you can record. Once that is done, the record button will show the record position and audio track scroll across the screen. You will also see the level bars respond to the input. When finished recording click the stop button. You should then be able to play back the recording.
There are many adjustment and changes you can make to recorded files. The Adobe help files are very good explaining the features of the software. It is a very powerful audio system. Good luck and have fun with voice and music tracks.
Thanks for using FixYa.
Gaker
Jun 15, 2011 | Computers & Internet
Is there supposed to be a special driver for this Labtech microphone? I am running XP and have all the volume controls active but it is not recording.
In addition to the instructions below you may need to make sure you have selected the right sound source (normally WAVE) in your recording program
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 25, 2011 | Labtec Microphone Microphone
DOES NOT RECORD ANYTHING ON MY WINDOWS XP
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Click VOICE
That should be it.
Feb 24, 2011 | CAD Microphones GXL2200 Professional...
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Click VOICE
That should be it.
Feb 21, 2011 | Audio Players & Recorders
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Click VOICE
That should be it.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
Just purchased Samson dynamic microphone. Can we use this with a portable stereo or computer? If yes, how does it work? What do we do to set it up?
You can use it with a portable stereo that has a microphone input socket - just plug it in. You may need to adjust a mic volume control - this will vary from one system to another.
With a computer just plug it onto the microphone input socket (usually colour coded red or pink)
You will also need to enable it in 'control panel' - see below.
Click VOICE
That should be it.
Feb 14, 2011 | Samson Dynamic Vocal Microphone
Can't Record and Only hearing playback via laptop.
Check you XP machine for SP3, go into the sound manager and make sure that the input your using is not muted and set as default.
http://www.ejoysoft.com/images/mixer.gif
Aug 04, 2009 | Edirol UA-4FX External Sound System
Cannot get microphone to work while connected to computer.
I found this on the Turtle Beach website: ________________________________________
Let's make absolutely sure that the microphone in your headset is working correctly. If the mic is working, a replacement talkback cable should fix it. If not, then please send in your name, shipping address, the name of the store where you purchased your X1 and the date (month/day/year) of purchase.
OK, here's how to test the X1 using the Microphone input on your PC:
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input) on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub, please).
4) In the soundcard's control software, enable the Microphone for playback. In the Microphone > Advanced settings, enable the Microphone Boost. Make sure the Microphone is not muted (Mute switch is not enabled).
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute (the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to work over Xbox Live, then you need to take a closer look at Dashboard settings and other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position. If it is on the ON position the Mic will not work.
Red = Muted Green = UN-Muted
_________________________________________________________________
If you're having trouble adjusting the Mic in Windows:
WINDOWS XP:
For Windows XP, there's a nice video on YouTube that takes you through all the steps of setting up your microphone: http://www.youtube.com/watch?v=Vissxo8furo
WINDOWS VISTA:
Please follow these instructions to configure your microphone within Windows Vista:
1. Left-click on the Start button. The Start Menu will appear.
2. Left-click on Control Panel. The Control Panel will open.
3. Left-click on the Hardware and Sound option. The Hardware and Sound window will open.
4. Left-click on the Sound option. The Sound window will open.
5. Left-click on Recording from the three tabs at the top of the Sound window. While in the Recording tab of the Sound window, you will see all options available for recording - Microphone should be one of them. (If you don’t see an option for Microphone, ensure your microphone is plugged into your computer using the jacks commonly located on either the front or back of the machine.)
6. Left-click on the Microphone option to highlight it. This will enable the Properties button toward the bottom-right of the window. Left-click on the Properties button.
7. You should see the Properties for your recording (input) devices. One of these should be Microphone.
8. Left-click on the Levels tab (or similar). Adjust the Level (Volume) and Mic Boost controls to at least half-way up. If your Mic Boost control is a simple check box, please make sure it is checked (Enabled). You should hear your microphone in your headset or speakers.
Once the levels are adjusted to your satisfaction, left-click OK and OK to save your settings. You can then close the Control Panel.
Your microphone should now be ready!
Apr 17, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Audio
Try the solution at the Xitel site http://www.xitel.com/USA/support_inport.htm
Feb 17, 2008 | Xitel INport (HFLI1X1) Audio Input
Xitel INport (HFLI1X1) Audio Input Logo
249 people viewed this question
Top Xitel Televison & Video Experts
CFB Software
Level 1 Expert
boneman1975
boneman1975
Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
