Question about Bose Audio Players & Recorders
Dropped a portable bose cd player and now it doesn't "read" CDs
I dropped my personal portable cd player and now it will not play any CD's. When I hit the play button the word "disc" appears.
  • gtwhite826 Jan 11, 2009
    i did try a different cd - how much would it cost to fix?
  • 22 Answers
Yeah im sorry but i think your cd player is junk now, most electronics dont survie a drop. did you try a different cd
Posted on Jan 11, 2009
Bose sound
You could try to clean the laser, with a special cleaning disk. Don't try to clean a laser by opening the player, you will damage the system.
If it is a CD burned in a PC, it also can be the laser is now a bit less, not capable reading CD-R or CD-RW, and still can read normal CD's
Read my other post over CD players
Jul 26, 2014 | Bose & Wave& Music System
Why won't bose play some cds
Could it be the CDs you can't play, are burned in a PC?
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 13, 2014 | Bose Wave music system Multi-CD Changer...
The CD player does hardly read self- burnt audio CDs although every one of my other cheap Players i have at home or in the car can read them.
The answer depends upon the age and precise version of your Bose system. Not all CD players can reliably read CD-R and CD-RW discs, and even those which do are sometimes picky about the brand of recordable disc in use.
In my experience, all of the Bose Wave systems I've worked on have contained surprisingly cheap/average parts inside considering the luxury price-tag. Either stick to using other cheaper (and often far better) CD players for CDs you've burned yourself, or look into getting the CD laser pick up inside your Bose replaced with one which is known to have no issues with CDs of different reflectivity to standard pre-recorded CDs.
Jul 06, 2011 | Bose & Wave& Music System
Cd changer is not reading disc even after it was cleaned
Please check the format of the CD. It should be commensurate with the formats which can be played by the CD Player. This information is available within the booklet which has been provided with the changer. To give you an example I purchased Bose surround system in 1998. It can only play CD's which are recorded in wma format and will not play any mp3 CD. Some of the CD players do not play re-writable CDs. Please check.
Dec 02, 2010 | Bose Audio Players & Recorders
Hi. I have owned my Durabrand Personal CD Player
Most likely the trouble is that the laser has just worn out and can't read discs any longer. The power drops with age and use, and sooner or later this happens to any CD player. The low cost of these personal CD players makes them uneconomical to repair.
Mar 11, 2010 | Audio Players & Recorders
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
The cd player is not reading the discs. The read out flashes and blinks but it does not read the music off the disc.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
Nov 13, 2009 | Bose Wave Radio
My Sony D808K portable CD player will not play a CD. When the door is shut the player should turn the CD and show info on the LCD display, but that doesn't happen. If I press the play button, it tries to...
It's dead. Mine did the same thing, but I noticed also that the disc never spun up fast enough to be read successfully. I'm guessing that the motor just lost its oomph. I imagine that one way or another it's fixable, but with portables so cheap and a player this old not being able to read anything but manufactured CDs, i.e., no CD-R, CD-RW, etc., it's not worth it. And mine was old enough to vote! :)
Jul 30, 2009 | Sony Audio Players & Recorders
Player will not play cd - it reads then says
Your CD player is failed. It will need to be replaced. Some folks can repair but it cost less to have it replaced. If no one local will do it BOSE will for about $150.
Jul 11, 2009 | Bose Acoustic Wave music system II -...
What does the Bose car cd player code ''CPED'' mean?
get a head cleaner, clean it and see. if it still comes up then its not dirty. its a cd problem.
Feb 26, 2009 | Bose 3 2 1 GSX System
165 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
