Question about Caterpillar Electrical Supplies
My Catepillar generator is producing 400v not 480v
    Prodigy:
    An expert who has answered 500 questions.
  • Caterpillar Expert
  • 573 Answers
You may have a bad exciter diode, short in rotor/stator check AVR output voltage to exciter also, Ohm exitier stator/rotor
Posted on Nov 27, 2013
Tip
Pioneer DVD-400V DVD Player HDMI Reset
Pioneer DVD-400V HDMI Reset
Model: Pioneer DVD-400V
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  1. Switch everything off.
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V Interlace Reset
on Jun 06, 2010 | Televison & Video
Tip
Download Pioneer DVD-400V Manual
Have you lost your Owner's Manual for your Pioneer DVD-400V DVD player?
Would you like a digital copy of the Pioneer DVD-400V Users Guide for easy searching of terms and quick reference?
The Pioneer DVD-400V manual is available free in pdf format, just follow the link below (& Click FREE):
I hope that helps.
________________________________________________
"i want to convert 400v to 220 v in stamford generator how can i do this ?"
split it with a regular breaker panel, your buddy the electrician will know
Apr 26, 2014 | Electrical Supplies
Olympian generator
I am ssuming this is a 50HZ unit? hence the engine speed with a 4 pole rotor which this has is 1500rpm. I also assume it is not one you are trying to convert from 60HZ to 50HZ? You never said what your countries voltage is? I assume when you say 400V is too high, you are looking at a 380V 3 phase power???
Based on that the engine speed is controlled by the governor control board, and if electronic Isy governor installed can be adkusted with a potentiometer. If youa re trying to slow down a 60HZ unit to 50HZ it won't work as you will get under freq fault.
The voltage is governed by a small AVR PCB in the alternator cover. pos an SX series AVR
Sep 20, 2013 | Electrical Supplies
Tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
I hope that helps.
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Tip
I hope that helps.
I am looking at a 480v fed chiller. It seems to be wired so they can also drive a 120v pump from the same 480v feed. Is this possible?
From what I found, 480 volt, 3-phase is 480 volts from leg to leg.
It is also 277 volts from each leg to neutral.
One can use a step down transformer to reduce the 480, 3-phase to 208 v, 3-phase and then each leg of the transformed voltage would be 120 volts to neutral. Try to locate the transformer in or near the chiller control cabinet.
Dec 23, 2010 | Mr Steam TRANSFORMER 1/4 KVA 480V/120V
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
139 people viewed this question
Top Caterpillar Electrical Supplies Experts
Todd Arndt
Todd Arndt
gbob59
Lawrence Oravetz
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
