Question about Lexmark W840 Printer
915 service motor error - Lexmark W840 Printer
  • Official Brand Answer
  • 3,344 Answers
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Posted on Nov 30, 2012
How to reset a 915 fan error lexmark w820
You will need to replace the failed fan before you can clear the error. Part Number 12G4005.
Sep 01, 2014 | Office Equipment & Supplies
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
How to come fatal error
a hardware failure.
hard drive, video card and overheating inside the computer is most likely the cause of fatal error.
how did you come to this error? on what instance?
Feb 08, 2011 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Infoprint 1145 ''915 Service Fan Error''
915 Fan Error Fuser fan failure
+24VDC CHECK
Measure the voltage at P/J456-1 and FG on the I/O PWB.
Is there +24VDC between J456-1 and FG?
Yes: Replace the “Fuser Fan”
No: Use the Block Diagrams in the printer service manual to troubleshoot a loss of +24VDC
The following printer FRUs and areas are associated with this
specific problem. One or more of these FRUs or areas may
have failed partially or completely. If you cannot isolate this
problem using the steps in this Service Check, replace each
FRU or troubleshoot each area listed below, one at a time, until
you isolate and solve the problem.
• Wiring and connectors linking the FRUs
• I/O PWB
Mar 23, 2010 | IBM Infoprint 1145 Laser Printer
What is ERR 1 Ec?
The "ERR 1EC" is a SERVICE ERROR CONDITION that usually indicates a faulty color "printhead assembly" or faulty "main board PCB assembly" [PCB = Printed Circuit Board].
Nov 06, 2009 | Epson Stylus Photo 915 InkJet Printer
Lexmark w820--915 fan service error - intermittent!
This error occurrs after having *** with the printer. Please refrain from this activity
Oct 01, 2009 | Lexmark W820 Laser Printer
Kenwood 915
If this unit is new, take it back as it may have a broken drive gear. if it is not new it will need to be serviced by an authorized Kenwood servicer. Good Luck
Jun 20, 2007 | Kenwood Excelon KVT-915DVD Car DVD Player
Lexmark W840 Printer Logo
335 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
