Question about Pioneer DEH-425 CD Changer
Hi I need to replace my electrical aireal on my poineer deh425
Only thing is how do i connect wire to power switch to operate aireal????
  • 15,935 Answers
In line
+12V antenna wier (blue/wht)__________switch___________Antenna Power wire
Posted on Jan 12, 2009
I am trying to hook up pioneer deh425 car stereo to my 99 dodge durango please I need wiring color codes for both thank you
go to a radio shack or like store and get a adapter plug to match your new unit , that way you don"t have to cut no wires and its a piece of cake to just plug in this thing will plug in to the dodge plug and the other end plugs in to your new unit
Nov 18, 2015 | 1999 Dodge Durango
Front wipers will not operate. checked fuse and relay look ok. back wiper works
Here are a few other things to check beside the fuse and relay:
Check Wiper Motor - the wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
Check For Break in Connecting Wires - the connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch - another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Check for Bent Wiper Arms - bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Nov 25, 2010 | 2003 Isuzu Ascender
Wiper stopped working...what is the problem
Wipers Not Working - Things to Check
To troubleshoot car windshield wiper problems, you need to thoroughly investigate problems with any of its operating parts. Here are some of the things that you need to check to determine why are your car windshield wipers not working.
Check Wiper Motor
The wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
The connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch
Another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Check For Blown Out Car Fuse
A blown up car fuse could be the culprit that has stopped the windshield wipers from working. Check the fuse assembly under the dashboard of the car. Replacing a blown fuse might fix the problem of windshield wipers not working.
Windshield Wiper Sprayers Not Working - Things to Check
Sometimes the windshield wiper sprayer stops working which can be very annoying. The washer mechanism is a self cleaning mechanism for the windshield. Here are some of the things that you need to check in case it is not working.
Check Windshield Washer Motor
The windshield washer mechanism might have been impaired due to the malfunctioning of the wiper washer motor. Check if its working and get it replaced if it is beyond repair.
Check Windshield Washer Fluid Level
Sometimes the washer doesn't work because the washer fluid levels are not filled to requisite levels. Filling in fluid might restore normal functioning.
Check For Broken Washer Hose
The connecting washer hose that connects the reservoir to the nozzle, might be broken or worn out stalling the overall operation. Check the hose for leaks and get it replaced.
Check Washer Nozzle For Clogging
Last thing to check is the nozzle of the washer for clogging. An obstruction in the washer nozzle might be the reason for windshield wiper sprayers not working. Using a pin, clean the clogged nozzle. This might restore the sprayer to the normal working condition.
Jun 07, 2010 | 1998 Saturn SL
Lights dont stay on
I must assume that when the light goes out (quickly after it goes on) that you can turn it on again very soon and the same thing will occur. This cold be an overload; that is, the timer is designed for handling 300 watts (as an example) and you have 400 or more watts of lighting, therefore the timer is saying this is too much and cutting off. Or there can be a bad light that is drawing too much electric such as a fluorecent light with a bad ballast. Or, if this outlet where the switch was, has only 2 wires that went to the old switch (and no other wires) then you may be feeding current into the new timer switch and shorting it out. The essential point is: is this switch outlet box with only 2 wires where the black and white both went to the switch, or are there more wires where 2 blacks (or a black & red) went to the old switch and the white wires are nutted together and not attached to the old switch.
You need to determine the wiring system within the box before you can determine how to apply them to this timer unit. Remember, the timer needs a nuetral and ahot just to operate, then it needs to feed this operated conrolled electric to the light via the red output wire. Regular switches do not work in this manner.
Apr 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
How do i wire a toggle switch tomy electric clutch orignal switch doesn't work.
Ther are two wires,one power one ground.The ground wire should be grounded already[confirm with an ohm meter.You need to put a power sorce to the switch and one from it to the pto this will make it work but will make all the safety switches in-operable so it is not a safe thing to do.Your best bet is to replace the swich or the safety switch that is keeping it from working[seat switch or brake switch usually].
Nov 16, 2009 | Oregon Scientific Electric PTO Clutch for...
Electric aireal doesnt work wont move
have you checked the activator connection, or tried connecting to live to test.
Apr 26, 2009 | Car Audio & Video
Installation Problem
Switches always connect to hot (black) wires. In some cases you may find a white wire with the end taped black denoting it is serving as a hot (black) wire. Or you may find a white wire connected to the switch. If that's the case, the prior electrician did not properly mark the wire and it should be marked as a black wire. Wrap the end with black electrical tape after disconnecting.
Aug 27, 2008 | Lutron CA-1PSH-LA Almond Claro Switch
Poineer dvd rw for computer codecs
What program are you using for the payback, what operating system are you using? as this help with the fix.
May 11, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
POWER SUPPLY FOR pc
The simplest would be to connect the power supply to a motherboard since this is where the on/off switch is also connected. The power supply needs to be triggered on before it will operate. Plugging in power from the mains is not enough.
Alternately in most PC power supplies, you can try force triggering to turn it on with just your fan and lights connected. This is done by shorting the Green (or Gray in some) wire to the GND (black) wire on the biggest connector.
In most modern power supply designs, it needs a load across the +5V rail (latch on) to operate otherwise it will power on but then immediately switch off when it senses that there is no load connected. Sometimes this can be defeated by shorting the Orange (Power Good) wire to the Red (+5) wire.
A word of caution, some old Dell power supply as well as a few other brands do not follow the standard wiring color coding
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Hope that
Dec 08, 2007 | Computers & Internet
Car Audio & Video Logo
73 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
