Question about Toshiba SBX4250 - Powered Soundbar and Subwoofer
Can't connect to tv
    Champion:
  • 226 Answers
Please refer to the operating manual that came with your unit. It will tell you all the details about how to connect the soundbar to your tv.
go here to download pdf
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su3461183/SBX4250KN_IB_V1_R13.pdf
Posted on Nov 30, 2012
When connecting tv to pc i'm getting an error message 'no signal input detected'
Did you click on the source button? Also you have to go to your desktop right click with the mouse thern click on properties you will go to your display settings you should see 2 display squares 1 & 2. now you can clone or extend. Another thing it would help to let us know you OS ie win xp or 7 or whatever. Whether you've got Nvidia or ATI or onboard Graphics. So I'm just giving you the basic info..Hope that helps Merry Xmas.
Dec 27, 2012 | Wharfedale Televison & Video
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
I just turned my digital receiver on & my LG tv & the tv says it's not programmed
Try to unplug from power both the set and the box for several minutes and then power both back up---this will allow both to try to reboot.
Dec 08, 2012 | LG 32LG30 32 in. LCD HDTV
Audio out locations on back of tv
Hello
You want to connect your TV with an external audio device, and want to hear sound from it, I assuses, and posts this solution.
There is audio out sockets at the back side of the TV, very near to S-Video socket. Marked audio "L" & "R". These two sockets are audio out socketsfrom TV to connect any external audio amp. Just use an audio cable to connect these sockets, to 'Audio IN' of the amp socket. Switch ON both the devices. You can hear the audio of your TV programmes by the amp you conneccted with.
The picture of the AV cable is given here. Take red and White colourd connections to connect the TV with amp. Left the Yello coloured pins free. It is meant for video. 2_11_2012_3_19_43_pm.jpg
Feb 11, 2012 | Element Electronics FLX3210 32 in. LCD TV
No sound on the tv but everything else works
Hello
Check whether 'mute' function is On. If it is ON, normally a embelm of speaker with a red cross over it will be displayed on the secreen with most of the TVs. You haven't given any details of your tV, brand name, model number etc:- so, i can oly give you general flault description. If mute is OFF, and still there is no sound output from your TV, check its speaker first. If speake is OK, check the set for it audio output, by connecting it with an external amp, by connecting the audio out rCA socet at the mack of the tv, to the audio 'in' of the amp. If there is audio out from the TV, you can heare audio through amp. If there is no audio from amp also, make sure that the sound fliter circuit inside your tV is faulty. If there is sound through amp, and no sound comes by the loudspeaker of the Tv, make sure that the audiou output section circuit inside your tV has the fault; provided speaker is good. OK.
Dec 08, 2011 | Televison & Video
How to connect my old wharfedale speakers to my led tv, bare wire type
you may have to connect them through an external amp using analog audio out on tv, these don't have speaker jacks for direct connection........Regards, Meder's Tv Service
Oct 06, 2011 | Televison & Video
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
How To Connect A VCR
your question is not clear enough. Do you mean "How to connect VCR to your TV?" If yes, then the below solution is the answer to your question. But if that's not your question, please rephrase your question for proper and accurate solution.
Connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
1. You can use a RF cord.
2. You can use a RCA cord.
I would suggest you use the RCA cord because the RCA connection has a better sound and display quality than the RF. So I would direct you on how to use the RCA connection method.
Here is a picture of what the RCA cord looks like for quick identification;
As you can see from the above picture that there are three cords. The Yellow cord is for display (video), while the with and red is for sound (audio Left & Right).
Turn of the VCR and the TV.
Look at the back of the VCR, connect the yellow to 'video out' and the white and red to 'audio out'. Note that the VCR might have only one audio out, that doesn't matter, just connect any of the red and white.
Now connect the other end of the cord to the back of the TV this way; Yellow will go to 'Video in' while the red & white will go to 'Audio in'.
Turn on the TV and VCR.
Select the TV to Source/AV and the display of the VCR should appear on the TV. Or better still, you can insert a cassette into the VCR, press play before selecting Source/AV on the TV.
By now the connection should be Okay.
If you any more questions or clarifications, please let me know as I would be glad to respond.....
Yours sincerely.
Elect_Comp.
May 26, 2011 | RCA Televison & Video
How do I connect a VCR with the TV
connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
Yours sincerely.
Elect_Comp.
May 24, 2011 | Sanyo Televison & Video
Toshiba SBX4250 - Powered Soundbar and Subwoofer Logo
1,135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
