Question about Sony SDM M61 16 in. Flat Panel LCD Monitor
Circuit diagram of 19 In SDM-E96D TFT LCD color display
Circuit diagram
pravinbhavsa
  • 348 Answers
SOURCE: Colors are off on various web pages--red links are
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Posted on Mar 05, 2010
SOURCE: sdm-n50 fault
I WANT THE SYSTEM CABLE OR IT NUMBER EXIST PLEASE
Posted on Feb 20, 2011
budmrtn
  • 11361 Answers
SOURCE: hey, i have this sony
It is telling you that the PC videocard resolution is too high, when you boot up insfae mode, the resolution is lower. Does it do the same when attched to another PC? You should set the resolution to the native resolution of the monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
budmrtn
  • 11361 Answers
SOURCE: my sony tft sdm e76d
It may have pwoer supply, backlights inverter, bad lamp assemblies problem, you need to open it up.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SONY monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Posted on Mar 25, 2011
  • 1606 Answers
SOURCE: No picture Display when turned
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
Posted on May 25, 2011
No display on monitor
There are a number of possible reasons after checking what you have so far. Have you checked that the video card has not been disturbed inside the computer?.
Try starting your computer in safe mode, see link below. Just in case you have a driver problem.
http://windows.microsoft.com/en-gb/windows/start-computer-safe-mode#start-computer-safe-mode=windows-7
Dec 21, 2013 | Sony 15 Inch Tft Lcd Color Computer...
Power supply sony monitor SDM-S204
TRY WITH A OTHER MONITOR ARE THAT OKEY YOUR MONITOR ARE PROBERLY BROOKEN.
ARE THE OTHER MONITOR ALSO BLACK YOUR VIDEOCARD ARE PROBERLY BROOKEN.
ALL CABELS SHOULD ALLWAYS BE SEATED TIGHT.
Jun 07, 2013 | Sony Sdm-s204 20.1" Tft Lcd Color Desktop...
No picture Display when turned on lots of Colour lines, could this be the inverter board problem. the model is Sony TFT LCD Color Computer Display SDM-X72 Serial Number 4530624 Manufactured April...
Dec 14, 2010 | Sony SDM-HS73P 17" LCD Monitor
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Connection diagram for pillow tft lcd color monitor
Need diagram for:
On Flap:
XF000FSCG5P
7 inch TFT LDC Digital Ca...Car Reaf View Camera Combl
Now
On Top:
12V-24V
Pillow TFT LCD color monitor
Apr 11, 2009 | Car Audio & Video
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Sony SDM M61 16 in. Flat Panel LCD Monitor Logo
81 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
