Question about Tools & Hardware - Others
How to replace switch and module 5140101-05
Im trying to replace switch in my snap on polisher using a replacement compatible de walt switch but in the process i lost the wiring position, can you help me with tht I will appretiate it
worldvet
  • 859 Answers
SOURCE: I have a kitchen ceiling
Bob, You will get some nonsensical responses to your post, just refuse them or rate them TFT and IA when appropriate.
We do have experts in this area if you will be patient enough for them to discover you post. And, actually, you could also post in the Free Forum as well.
From my experience which isn't current but years old. Black goes on L, as you probably guessed. Then I would use yellow on 1, orange on 2 and purple on 3.
If your fan doesn't start on highest speed, cycle through tugs until you get high speed and then note how many tugs to get the slowest speed. This then will tell you which wires are fast and slowest. Lable those and reposition them on the switch. As you probably know, the highest speed should be on first pull from the off position.
Regards,
Worldvet
Regards,
Worldvet
Posted on Sep 06, 2008
honeymokey
  • 3113 Answers
SOURCE: intermittent crank no start. intermittent shut
Check the number on the ECM . If it has the number 1228253 on it that is your problem. They had a cutting off problem while driving. Get one with the number 16198264 on it. The 1228253 is junk and gm replaced them with 16198264.
Posted on Nov 06, 2009
SOURCE: small junction block for TDX system 3 position switch broken
figured it out myself and didn't cost me a freaking dime. Thanks for nuthin.
You should say it costs money up front to ask questions in a post, before all the time wasted posing questions and descriptive information.
Posted on Jan 25, 2010
  • 122 Answers
SOURCE: De Walt Power Shop DW125. Cutting problem.
Sounds like a dull blade or not enough teeth on the blade. Go with atleast 40 tooth.
Posted on Feb 02, 2010
  • 15 Answers
SOURCE: de Walt DW988 XRP 18v 1/2" Hammer Drill have
Depending on how much play, thats normal. The hammer feature causes that.
Posted on Jan 25, 2011
How to replace brushes in de walt drill
If you are mechanically inclined it isn't too hard. If you already have the replacement brushes then it should take about 15 minutes to replace. Be sure and replace both and not just one brush. Be careful with the new ones as they can be a bit brittle. Check youtube to watch people change out brushes. Most drills work the same way.
May 28, 2014 | Dewalt 176846-03 Brush
De Walt DW988 XRP 18v 1/2" Hammer Drill have
Jan 25, 2011 | Dewalt Drills
Milwaukee 18volt impact wrench has no power batteries are good, motor brushes seems to be ok
i have the same impact an replaced trigger switch. i think it was 38,00, had the same thing happen with my de walt xp hammer drill.U can check switch continuity before replacing
Jan 06, 2011 | Milwaukee 0879 22 V18 Impact Wrench Kit
Hi, i have a 18v rechargeable hand held vac (pirana brand). It wont hold charge or wont even charge. What can i do to revive and/or where can i get a replacement battery? Thanks
Before I gave up completly on this battery I would remove it from tool and put battery in freezer overnight. Remove from freezer and let set at room temperature for several hours. Try to charge and see what happens. I don't pretend to know why this works but I have done this with every thing from ceel phone batteries to cordless drills and several other tools. If you need a new battery you should be able to get one at any hardware store that carries De Walt tools. I know arond here True Value is one that carries a large selection of De Walt tools and supplies. Hope this helps. Thanks
Nov 16, 2010 | Dewalt Accessories Batteries 18 Volt
Where do I order a replacement transceiver
https://www.gbic-shop.de/de/produkte/transceiver/sfp/kompatibel-6/1000base-sx/cisco-glc-sx-mm-detail.html
Please visit this site.........
gbic-shop.de is a manufacturer of optical transceivers.
We produce any module compatible to all brands, suitable for all systems. SFP, XFP, SFP+, X2, Xenpack, QSFP or GBIC - as Ethernet, Fibre Channel, CWDM or DWDM with or without DOM/DDM.
Apr 05, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Drill Is Dead Fuse O.K.
Check the brushes for wear.
Most likely the cord has a broken wire , usually happens close to the handle of the drill.
To test, split the case ( puzzle screwdriver bits are avaliable from hobby shops ) and run a test light on the cord from the plug to the switch.
If the cord is ok , test the switch , they are quite flimsy on De Walt tools so be careful.
If the cord is faulty cut the damaged section out and shorten it.
If the switch, replace it . Check price, they are very hard to get here in New Zealand and very expensive.
If the Brushes, these should be avaliable from your De Walt retailer.
While you have your drill apart, check the bearings, De Walt uses common sizes,easily avaliable from a bearing shop and prone to seizing up and burning out the armature.
Mar 17, 2010 | Dewalt DW505 Electric hammer drills
Feb 02, 2010 | Dewalt Saws
Tools & Hardware - Others Logo
64 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
