Question about Watches
I can't remove back of "my wish" watch.
Jeweler said back of watch cannot be removed. I paid $20.00 plus shipping for watch. Why can't it be removed?
    Sergeant:
  • 302 Answers
Maybe he can't, doesn't mean it can't come off. Find a more competent jeweler or watchmaker. If it is true the back can't come off then the watch comes out through the top or crystal. Did you pay $20 for the watch or $20 for shipping?
Posted on Nov 30, 2012
SOURCE: My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Posted on Jul 28, 2007
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 299 Answers
SOURCE: I recently received a Tag Heuer Link Calbre 5
Here is how its done. First remove one end of the clasp (this is much easier on the adjustment side - just depress the pin and remove). Now you can separate the two halves of the first link (actually this is a half-link). Simply grab each half and pull. You may have to do some twisting - do it carefully so that you don't bend the pin. You may have to do some prying - if so, you can use a thin piece of plastic so you don't scratch the link and only pry along the pin so that you don't bend it. Once removed, you can now remove the first full link. Remove it in the same way. Now replace the end half-link and re-attach the clasp. Removing a link from the other side is a little more difficult. The clasp lock is held on with a long pin (slot on one end and screw on the other. One must be held in place while you turn the other. You may need another pair of hands to help you.
If you feel uncomfortable about any of the above, take it to a jeweler - a Tag AD is not necessary but probably best although any jeweler can remove a link if they understand how they are put together. Tell them the link is composed of a right and left half that snap together and they should then see and understand what they need to do.
Posted on Apr 28, 2010
  • 3 Answers
SOURCE: Hi. I have a
Hi Susan, most Watches will require a tool to remove the back, some use a knife like tool, and some use an adjustable key type tool to fit the slots of the watch cover, so that you can unscrew the back off. Sometimes you can use a thin knife too, be very careful not to cut yourself, and also not to damage the rubber gasket. The gasket sometimes will need replacement on some watches if they are waterproof. I recommend having a watch expert look at it if you feel you can't do this yourself.
Also the tools are available on eBay. I hope this helps you. Joe
Posted on Mar 14, 2011
How do i change a battery in a quick silver watch (Viper YO15DV )
  • Remove back
  • Find battery mounting. Note mounting arrangement and polarity for future.
  • Identify battery type.
  • Obtain new battery
  • Remove old battery. Install new.
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery
Take your watch to
Nov 29, 2016 | Watches
My watch glass fogs when I wear it on cold days
Yeah, it does not say it is waterproof, I have one they are "Water Resistant" to like 165' or some such nonsense. Anyway, if you paid for a warranty you can have it repaired by Diesel, this is the 1st watch I have ever purchased where they ask at the counter if you wish to purchase the manufacturers warranty. Mine was an extra $35 for the warranty. Yours may have been included in the price? If not your choice is deal with the fogging, repair it yourself, or pay a jeweler to repair it properly. You don't necessarily need jeweler's tools to repair it, but it is very easy to gouge the watch without them. New seals are available online. Personally I would take it to a jewelry store that offers watch repair. Your other option is to send it to Diesel, but you'll be paying for shipping/handling plus repair costs without warranty.
Dec 03, 2014 | Diesel DZ7257 Watch
How do you remove JARAGAR watch links?
Most likely it is going to be with a needle press... available on both eBay & AMAZON... but unless you are planning on having a lot of wrist size changes... or a large collection of HIGH END watches...
You would be better off to take it to a serious jeweler
Carnac the Magnificent
Invicta Watch Sizing Tool
Professional model (best chance of scratch/marring ur band)
Zacro Watch Band Strap Link Pin Remover Repair Tool Kit for Watchmakers...
Feb 28, 2013 | Watches
Reset casio databank 150
remove battery and wait about two minuteslook http://www.pmwf.com/Watches/Casio/FirstMemoryProtectReset.htmand for other casio watches
Mar 05, 2012 | Casio 150 Memory Metal Band Databank Watch...
Just to know to open up the back of this Lorus watch, to replace the cell ?
Watch backs open three ways, the first way is 1) by small screws you will see them and need to remove them carefully as not to strip the screw head, if there are no small screws the watch could have 2) a screw back, it will have indentations evenly spaced all the way around the back, if it is a screw back it has to go to a jeweler or watch repair for removal with a special tool. You must eliminated 1 and 2, then 3) would be a pop off back, you look around the edge of the back for one indentation along the back of the watch, use a pocketknife to gently pop the back loose. I hope this helps! thank you!
Sep 21, 2011 | Watches
I DID NOT AGREE TO $20,00 FOR THE PIN WHEN IT WAS ONLY 15.00 320740462869
I assume you are referring to an Ebay auction item that you won.
You must always remember to factor in the additional shipping costs as well as the initial purchase price of the item.
The shipping costs to your particular location will always be listed just below the purchase price on the Ebay item's auction page. This price can vary for each buyer depending on their location so it is listed seperately. However, when you purchase an item you are also responsible for paying the listed shipping cost as well.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 15, 2011 | Watches
I need to know how much my watch is worth
What kind of watch is it? Is there a model # ? What are it's features & what's it made of? Try a jeweler, watch dealer or possibly a pawn shop for an estimate of the value - a jeweler who sells higher end watches is probably your best bet.
Jul 01, 2011 | Watches
How do you get battery out of watch? Do I have to take out all screws and remove top piece?
The back of the watch has six rectangular notches around the edge. Using a jeweler's case wrench and 4-pin vise to hold the watch align the three teeth of the watch to three of the notches on the back and turn counter-clockwise. Considering that the tools alone are going to cost you a minimum of $30 - $40, and then you'll have to purchase a battery for $5 - $7, I'm going to recommend that you have the battery professionally replaced for $10 - $15 at your local jeweler. Keep in mind, I'm also considering the fact that you suggested dismantling the watch in order to change the battery. This is obviously an indication that you have no experience in the most basic servicing of a timepiece and to ensure that your timepiece isn't damaged, you really should leave this to a professional. Watch Back Example and Case Wrench captainhawk1_16.jpg
Jun 19, 2011 | Invicta 2358 Wrist Watch
What kind of battery do I need for my watch-Fossil FS3028
Fossil watches typically have an 11-year warranty. If you're still in this time frame, you can send it back to them for replacement at:
SHIP TO: METRO SERVICE CENTER
ATT: REPAIRS DEPT.
10615 SANDEN DRIVE
DALLAS, TEXAS 75238
This is often the only way to get it replaced. If you're not within that time frame, you can try checking a local watchmaker's shop (you can find them in your phone book), and, barring that, you can try a jeweler's shop. But I would suggest sending to Fossil if you're still in the warranty period.
May 02, 2011 | Fossil Watches
Need to change the battery and take off the steel back of the watch
This may be a threaded backplate and removing it without the proper tool may cause some damage you won't like. Most jewelers will sell and install the battery for a modest price.
Mar 22, 2009 | Swiss Military Watch
Watches Logo
619 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
