Question about Lexmark Wheelwriter 1500 Typewriter
Only typing half letters and numbers
My typewriter just started typing the top half of all letters and numbers. I cannot figure out the problem. It just started doing this a few minutes ago. Can you help???
  • elainegam May 20, 2008
    What is a platen?
  • 163 Answers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Posted on Jun 08, 2007
  • Lexmark Master
  • 3,594 Answers
Elaingam
The platen is the black rubber roller.
DickyO
Posted on Jul 12, 2008
  • 480 Answers
Check the ribbon is it folding over?
Posted on Jun 09, 2007
    New Friend:
What about on an old Royal typewriter? same thing, MediaMan?
Posted on Jun 17, 2013
Thanks I had this problem and MediaMan85 your solution worked.
Posted on Jan 24, 2008
Everything seems to be locking in but the IBM Personnel Wheelwriter 2 only typpes the top half of the letters. I put in new ribbon and checked everything else. Can this machine lock itself into doing this?
Posted on Dec 02, 2009
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
Why does my typewriter only type the top half of the under-case letters?
There is most likely something interfearing with the type bar segment try ing to lift up, try pulling it up by hand.
DICKYO
Jun 17, 2013 | Royal Office Equipment & Supplies
My Swintec 7040 when I type a letter or word only write a half of the letter or the word and when I try to erase a letter or word the typewriter erase this but the erase ribbon stay in the same position...
There are a few possibilities. If only the tops are printing Press down on the platen to be sure it is fully seated in the side frame. The T/W may be in the overstrike ribbon mode Code period, comma or slash will get you out of that mode.
DickyO
Oct 11, 2011 | Swintec 7040 Typewriter
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
IWhen i turned it on it only types half the letters/numbers etc
If it is only typing the top half of the letters the platen may not be fully seated in the side frames, push down firmly on both ends of the platen it should snap into place.
DickyO
May 11, 2010 | Lexmark Wheelwriter 15 Series II...
Typing only half letters
Possibly the lower edge of the ribbon has become folded over during fitting, it happens.
Apr 19, 2010 | Smith Corona Wordsmith 200 Typewriter
Wheelwriter 1500 is only printing the top half of the letters.
I have solved the problem. It turned out that the platen was not completely secured on the left end. Once I snapped it securely in place, the print was fine again. (I had to remove that platen three times to figure that out!) Sorry for the bother, but I'm glad to know where I can seek help now. Thanks.
Mar 25, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
2,096 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
