Question about Maytag MHWE200XW Washer
Maytag washer 2000 series has no power to control panel
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Posted on Sep 27, 2008
  • 33 Answers
SOURCE: My maytag commercial 2000 series
Verify if the shipping bolts were removed. The machine will be shaking and moving if they weren't. In the back of the machine there should 4 big bolts attached with nuts.
Posted on Mar 14, 2011
jagans504
  • 31 Answers
SOURCE: Maytag series 2000 front load washer poers on but will not run
I am not familiar with this model, but if it has a filter, clean it out. Unplug machine first, and place a catch pan under filter if possible. Have a mop and bucket handy.
Posted on Jun 08, 2012
I have a maytag 2000 series front load washer and the door is stuck. Is there any way to manually open it? Its a MHWE250XL model.
For MHWE200X series (could not find specifics on the 250XL)
Did all of the water drain out of the washer during the spin?
Select RINSE, DRAIN & SPIN to remove any water remaining in the washer. The washer door should unlock at the end of the drain.
Is the door locked and is the "Add Clothes" light on?
Press START/PAUSE once. The door should unlock.
If the issue is not that ... but indeed having a stuck latch then there were references that the method below would work on some Maytags:
UNPLUG the washer and remove the bottom front service panel. Carefully reach up along the inside of that front panel and pull down on the manual release tab that is on the bottom of the door latch assembly.
If your machine does have a bottom service panel ... then there should also be taped somewhere inside the machine the technician service paper work which can usually be helpful also ...
Helpful?
Good luck on your troubleshooting!
Mar 11, 2018 | Maytag Washing Machines
Maytag 4000 series washer won't start, once you press the start button machine power off..
Power off means a short circuit. Either the PC controller board has a defective part or the safety electronic / shut down protection has indicated a fault and opens to prevent a fire, electrical damage, or other condition.
Feb 07, 2018 | Maytag Washing Machines
What does F7E1 mean on a maytag 2000 series washer
water flow error. Clear out trap under front panel. This will allow washer to run. Also drain will improve
Jan 13, 2018 | Maytag Washing Machines
Unlock door lock on maytag washer
Here is a link to a video that may help
http://www.youtube.com/watch?v=g2cFmKJZY0M
Copy and paste in your browser
Feb 16, 2015 | Maytag Washing Machines
Maytag 2000 series washer door locked
not a maytag 2000. mine doesn't have an access panel in the front. not a small round one on the lower left.
Apr 01, 2012 | Maytag Washing Machines
My control locked button is lit on the control panel of my front loading Maytag Epic. Therefore, I cannot start a new load (which I just put in). The door easily opens and shuts as itnormally does. Any...
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. So, holding the "OFF" button will not clear it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
Series 2000 washer starts to fill then powers off
IT SOUNDS LIKE YOUR TIMER IS GONE ON YOUR WASHER. IT SHOULDN'T COST THAT MUCH TO REPLACE.
RODNEY
Apr 04, 2009 | Maytag PAV2300 Top Load Washer
Maytag MHWE200XW Washer Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
