Question about Maytag Neptune MDE5500AY Electric Dryer
SOUNDS LIKE A BELT IS BREAKING AND HITTING THE INSIDE OF THE CABINET
I want to get inside and look around at the belt?If I have to replace it do I have to take the back off or the top or both?
    Sergeant:
    Champion:
  • 318 Answers
Remove the top sheet metal screws at the top rear of this unit,,then pry up the top,,,back to forward!!!,,,then have a look at the belt,,,,Replacement cost of belt usually around $12
Posted on Jan 16, 2009
My whirlpool duet sport dryer made a loud bang then stopped working and now says its sensing,,what could be wrong
Try reaching inside the dryer and turn the drum by hand. There should be some resistance because of the belt going around the drum. If you can turn it freely my guess would be the bang you heard was the belt breaking and the idler pulley hitting the floor or the side of the dryer. Most dryers today will not run if the belt breaks because of a safety switch. Hope this helps.
Jul 23, 2014 | Whirlpool Dryers
Manual on How to replace belt
  • 1
    Remove the power cord from the wall outlet.
  • 2
    Open the dryer door. Remove the screws located along the inside of the doorway with the Phillips screwdriver.
  • 3
    Pull the top part of the front panel away from the MDE5500AY dryer to disconnect it. Lift the front panel up to disconnect it from the metal clips on the dryer cabinet.
  • 4
    Unplug the wire connector leading to the door switch.
  • 5
    Unscrew and remove the four screws connecting the front panel to the rest of the cabinet. Lift the front panel up and away from the dryer to remove it.
  • 6
    Pull the idler pulley toward the left to relieve tension in the belt. Slide the belt off of the idler pulley and the Neptune dryer drum.
  • 7
    Route the new dryer belt around the drum and along the pulley system. Release the idler pulley to restore proper tension in the belt. Rotate the drum to ensure the belt is positioned properly.
  • 8
    Replace the front panel onto the dryer cabinet. Replace the four screws that connect the front panel to the cabinet of the MDE500AY dryer.
  • 9
    Plug the wire connector into the door switch assembly. Lower the front panel down into its original position.
  • 10
    Replace the screws along the inside of the doorway.
Sep 18, 2012 | Maytag Neptune MDE5500AY Electric Dryer
How to get inside and replace belt on washer model fws445rbs4 serial xc72602766
To replace that belt,use a flat blade screwdriver and place it between the top edge of front panel and top at the corners and pop up the top,raise the top,inside of the front panel at the top inside corners will be screws that hold the panel to the cabinet,remove those screws and push down and pull off front panel. To replace belt lay on the floor and grab old belt and rotate it off of the transmission pulley and pull it out,place new belt around motor and idler pulley and rotate it around the trans. pulley in a counterclockwise direction
Gene
Aug 10, 2011 | Frigidaire Washing Machines
My dryer starts to squek real loud when it is running
The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Dec 28, 2010 | Hotpoint Dryers
    Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
    1. remove top plastic panel (retaining screws are at back)
    2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
    3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
    4. Repeat for left side.
    5. push the back and front halves of the cabinet away from each other
    6. slide the new belt around the front of the drum
    7. reassemble
    8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
    Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
    How to replace belt on tricity bendix aw440 washer
    7. reassemble
    Oct 12, 2009 | Tricity Bendix Washing Machines
    Putting the belt back on this dryer
    Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
    Jun 26, 2009 | Hotpoint Dryers
    The belt broke drum won't turn
    Jun 25, 2009 | Roper REX3614KW Electric Dryer
    How do i?
    Apr 05, 2009 | Kenmore 63942 Dryer
    Dryer heat but what turn
    Mar 28, 2009 | AEG T57800 Electric Dryer
    Maytag Neptune MDE5500AY Electric Dryer Logo
    74 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
