Question about Cameras
Polaroid tablet 8-in wont accept any sd cards?
My friend gave me her polaroid tablet for a early Christmas gift today and for some reason it wont read ANY of my sd cards. It wont can them and even when the sd card is in the tablet is says no sd card. I tried resetting the entire tablet and even adding a song onto my sd card from my computer and put it back into my tablet and it STILL wouldn't read it. I can't download anything or take pictures without the sd card. I don't know what's wrong with it and hopefully there's some kind of solution to it! It's the Polaroid 8in internet tablet from Kohls. If that helps. I just can't figure out what is up with it.
  • Cameras Master
  • 19,719 Answers
Look for a format command within settings on the tablet. Also, there are different types of SD Card.
SD card TYPES - Google Search
Posted on Apr 08, 2017
SOURCE: polaroid a300 camera is saying sd protected
Well, make sure you have checked the small gray tab on the left side of the sd card. It needs to be in the unlocked position. Too bad for me, because i have the same problem and my sd card isn't locked...
Posted on Dec 19, 2007
justaplumber
  • 98 Answers
SOURCE: SanDisk memory card error
Try this link, card recovery software.
http://www.cardrecovery.com/?rid=google&kid=cr0110
Posted on Dec 25, 2007
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
Agent Allan
  • 480 Answers
SOURCE: sd memory card is locked and wont unlock
Hey rpl2125,
It sounds like you covered your bases, but you could try putting a piece of tape over the write protection switch and see if this works. If the tape doesn't work then there is most likely a defect in the memory card and you are going to need to replace it, and I would contact the manufacturer to see if it is under any warranty, and if it is they will often just send you out a new one.
Sincerely,
Allan
Go Ahead. Use Us
Posted on May 14, 2008
SOURCE: Memory card says it needs to be formatted but i have pics on it and I need them..please help I will be waiting!
I had the same problem with my 4Gb card that has 750 photos on it. I tried doing different things, however, it did not work. At last I took the card out and blew on its chips, gave it a good shake and put it back. Then, the miracle happened. It could read all my photos. I guess there was some dust that had accumulated on the chips at the back of the card. Hope it can help you, too.
Posted on Nov 06, 2009
What kind of sd card is compatiable with p902/a900?
MAKE SURE THAT THE SD CARD IS UNLOCKED OTHERWISE YOU WILL NOT BE ABLE TO WRITE TO IT.
Jan 27, 2016 | Tablets & eReaders
Why wont my Polaroid 4 in tablet hold any data?
you need an addtional sd card to store your data. can use up to 32 GB micro SD card.
Jun 06, 2014 | Polaroid 8-Inch Android 4.0 4 GB Internet...
My Polaroid Tablet will not download content. My internal sd card is full, could this be the problem? Also how can I access the internal sd card to erase content?
You should connect the phone to any system, which could regogonize the internal SD card. Most system will recogonize it. You can choose the SD card, and can delete the contents you wish to do.
Sep 27, 2013 | Polaroid Tablet Computer PMID701
My Polaroid tablet ptab 8000 will not read a micro sd card. How can I format the sd card?
Will it read other cards? If so then it may not accept high capacity cards, or need to be reformatted. If high capacity is the issue the the only thing you can do is get a smaller card.
If format is the issue then take a computer and a memory card reader (if the computer does not have one internally), insert the memory card into the reader and go to whats ever disk utility you have select the memory card and format it to the specification of your device. Done. It may be a task to format a memory card from windows so use some type utility or the command prompt if you are familiar with using it.If it wont read any memory card then the reader built into the device has malfunctioned or not properly functioning--Good Luck.
Jan 27, 2013 | Cell Phones
Myh polaroid pdc4350 wont accept a scan disk sdhc card 4g but will accept sd cards?
That is correct. While SDHC cards will fit into SD slots, they are electronically incompatible. SD cards will work in SDHC slots but not the other way around. You need to go with SD cards 2GB and smaller.
Mar 19, 2011 | Polaroid PhotoMax PDC 4350 Digital Camera
What kind of sd card does a polaroid mp3 model pmp280c-4 take.
mini-SD card. Here is a 4gb one on amazon for $7.99 (your device can take up to an 8gb card but make sure you get a MINI SD and not a regular SD.
http://www.amazon.com/Kingston-microSDHC-Memory-SDC4-4GB/dp/B000VX6XL6/ref=sr_1_2?ie=UTF8&qid=1298999885&sr=8-2
Mar 01, 2011 | Polaroid Audio Players & Recorders
Cameras Logo
1,418 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
