After installing windows vista my HP won't read my
  • 7,627 Answers
Try a re install of Vista. What happens when you try to boot? Did you format the HDD? Was the install successful?
Posted on Nov 30, 2012
  • 497 Answers
SOURCE: I'm trying to install Windows Vista on a new hard
This problem may occur if the DVD drive's firmware is either out of date or defective.
Check the link given below for detail information:
http://support.microsoft.com/kb/930984
To resolve this issue, obtain the appropriate firmware update for the computer's DVD drive.
Good Luck!!!!!!!!!!!!!!!!!!!!
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: I have an HP Pavilion
try change places 1 and 2nd HDD
Posted on Mar 30, 2010
  • 68 Answers
SOURCE: Won't boot from dvd or
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
Posted on May 31, 2011
  • 129 Answers
SOURCE: My HP DV9740US laptop will
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
Posted on Jul 28, 2011
Testimonial: "This is exactly what i needed! I had forgotten how to do that! You're the MAN!! Thanks so much for the help!"
  • 3940 Answers
SOURCE: Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Posted on Sep 11, 2011
I installed windows XP professional version 2002 but it doesn't have sound and I cann't get internet,my pc HP s3220n before hard drive damaged it was windows Vista,please help !!!
You have to install the drivers into your computer. You can get the drivers for Windows XP in the website of your computer's manufacturer. Since you cannot connect to the internet using that computer, then you can use a different computer. Download the drivers and save them into a USB storage device. After downloading all drivers, install them in your computer.
If you want to make sure that all drivers perform well, then I suggest that you keep them updated. You can use RadarSync if you don't want to do all updating manually.
David
Apr 15, 2013 | HP Pavilion Computers & Internet
Windows vista recovery cd I created won't install on new hard drive
Which software did you use to create the recovery disk? Is the recovery disk a CD or DVD?
Just to recover a vista system from recovery DVDs would require at least two DVDs. Your files would be in addition to this so I would be very surprised if you have only a single disk containing both the operating system and all of your files.
A simple recovery disk would only be useful for restoring lost operating system files to a hard disk that had corrupted or deleted files. It would let you restore to a new blank disk.
If the disk only contains a backup of your data then you would need to first install an operating system (Vista or Windows 7) and then install the backup software you used to create the disk and then you could recover your data from the disk.
Jan 05, 2013 | HP Computers & Internet
How to wipe hard drive and clean install windows 7
Sounds like you may have purchased a "Windows 7 upgrade" (whatever version Home/Pro,) version....
now that win7 is on it, you can boot from the CD, choose the "repair my computer" option, then choose the Advanced Startup repair options....and you can use the command window to re-format, or delete the partition and and re-format the drive....then start-over with a clean disk.
article to read on getting it to 'authenticate' if you DID buy Upgrade media and you want to do a clean install, (normally it won't without some tweaking.)
http://www.maximumpc.com/article/howtos/how_use_your_windows_7_upgrade_disk_fresh_pc
Tallon41
Sep 15, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
Switched a vista hd to a xp hd and windows will not open
You can't do that, it just won't work. A hard drive with XP installed on it will be unrecognizable to a PC with vista already installed on it. You can either backup your XP drive by putting it into a compatible XP computer. Or you can buy on of these, which are handy. This let's you get the data to your new PC thru a USB connection.
Mar 26, 2012 | Dell Dimension E520 PC Desktop
I'm having problems with my HP laptop. It won't start because there seems to be a problem with its booting device. Now it prompted me to insert the windows installation disc. The problem is, when I...
When you first turn on the computer it should display a HP logo for a few moments, on this screen near the bottom will be a message telling you to press either F10 or F11. Press the indicated key and the recovery process will begin without an installation disk needed. The files are there on the hard drive and will be used from there.
Sep 11, 2011 | Microsoft Windows Vista Ultimate Edition
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
Can I install the hard drive of my old hp 8510p in my hp presario cq 42? will it run the old windows vista? My new hp presario cq 42 is running the new windows 7?
If the hard drive is compatible with your presario cq 41 then it will work. The operating system does not matter if you're switching hard drives.
If you want to update the operating system on the old hard drive, you will need to have the software for Windows 7.
Jun 14, 2011 | Compaq Computers & Internet
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
