Question about Morphy Richards 43691 Cordless Electric Kettle
My ketle is shorting out when switched on.. what do I do
When switched on, kettles fuses the elecric system iis thea asort and how can I get it repaired
2 Suggested Answers
ruthfbrig35519
  • 81 Answers
SOURCE: how do I remove limescale from inside an elecric
Removal of limescale from inside an electric kettle is very easy one simply needs to use hot water for it. Simply pour it there and keep it for half an hour, then you will see that the limescale is scrapping off and Voila your problem is solved. For more details, please click here:
Top 5 Best Electric Kettle
Posted on Jul 23, 2015
Fuse #47 blowes on my 2000 focus all bulbs are good
it only means that your elecrical system on your running light was grounded thats why everytime you switch on the running light the fuse blown. The only solution to that is to find out where the line was shorted or grounded. you must start tracing it from your switch going down the elecrical line going to the fuse, relay and lights.
That's it, good luck then.!!!
Oct 01, 2012 | 2000 Ford Focus
Fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
Sep 02, 2012 | Russell Hobbs Kitchen Appliances - Others
Haden kettle blows fuse
Most common cause to start with is a shorted heating element.
Jerry G.
Jun 19, 2012 | Haden Kitchen Appliances - Others
New elecreic kettle . problem being with aftertaste from the water, any ideas?
Try boiling it several times, even if you put a few table spoons of bleach in it. Then give it a boil to clear it. If that does not take away the aftertaste, return it to the dealer for a refund or exchange on another make.
Feb 13, 2011 | Philips Kitchen Appliances - Others
How do I remove limescale from inside an elecric kettle?
You could buy in any grocery shop and in the net any brand of KETTLE and THERMOS DESCALER! Just put it in ur electric kettle and leave it for a day, it will disslove those lime scales! Taah!
Nov 12, 2010 | Morphy Richards 43072 Cordless Electric...
Brokem switch on bodum kettle,
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Jun 25, 2009 | Bodum Electric Kettle
Kettle does not work
you have probably re-wired the switch incorrectly or there is water in the wiring and the circuit is shorting, causing the fuses to blow. Also, is your electricity supply 120v or 240v?
Jun 15, 2009 | Benchmark 11065 Popcorn Maker
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Morphy Richards 43691 Cordless Electric Kettle Logo
56 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
