Question about MSI KM2M Combo-L (MS-6738-010) Motherboard
One short beep two long beeps redlight on startup
I was replacing the ram in my. Upon starting it up I got no display. So I began to systematically troubleshoot. Not in this particular order
1- disconnected the battery on the mobo for a half hour.
2- replaced the new ram with the old ram same beeps
3- unseated and reseated the video card same beeps.
4- removed the heatsink and processor removed the hardrive connector not only did I get the same beeps I got a redlight
5 It's not the video card I bought a new one today
I have tested and retested. With one stick of ram and video card only. Bottonline is I'm getting the same beeps no matter what I do . does anyone have any idea whats wrong with this computer. Any suggestions will help. Th computer am using is a Compaq Evo 51c
2.0ghz single core processor.
  • 68 Answers
RAM usually goes in pairs. Do tests with two sticke. They have to be identical
Posted on Jan 11, 2009
2 really short beeps and then 6 short beeps upon startup no display zt systems desktop
This indicates RAM failure, Try one RAM chip, then the other, individually. try different slots.
Dec 29, 2017 | Computers & Internet
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Its D51s. it gives one long beep and two short ones with no display. Initially it was working but when i removed RAM and on reinstalling it, it started giving me this beeps
Beep codes vary but 1 long and 2 short usually indicate a video problem. Since your problem began with removing the ram try this. Remove the memory modules again and re-seat firmly. If you notice the memory channels are dusty blow them out before re-seating. Hope this solves your problem.
Apr 12, 2011 | HP Compaq d530c PC Desktop
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
Getting a single beep upon startup, no video signal going to monitor.
One beep means everything posted right
I would start with the video card and pull
it out of socket then reinsert it you could
have a bad card or bad cable or the
mother board cant handle vcard
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 14, 2011 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
My computer keeps recylcling through the start up and I originally thought it was a bad hard drive but I took it apart and found that my fan was running and the hard drive seemed to be spinning. The...
Exactly how far does your computer get before it restarts? there is normally a short beep during the startup phase, do you hear the short beep, or is it a long beep or a combination of different beeps?
I am not saying that it cannot be the power supply but usually problems of this sort are a faulty graphic card or faulty RAM, worst case senario is a faulty motherboard. The first two you can test by adding an extra graphic card or replacing the RAM (or taking one out and then the other if you have more than one RAM) - BE AWARE that you can damage your computer or the RAM itself if you touch the wrong things and you are have a static charge.
Oct 20, 2010 | Bestec (ATX-250-12E) 250-Watt Power Supply
Durin start display stays black and one long beep
Based on the information provided, looks like some peripheral or component failed. This abnormal beep means some components (like RAM) is either not functioning OR is loosely connected etc.
If you are comfortable with your desktop, i would suggest >> (1) checking if the RAM modules are inserted properly or not. (2) Checking if the Video card is inserted properly.
Sometimes RAM/video card etc get loose due to a shock/**** etc, and hence the abnormal beeps.
If you are not comfortable with opening your desktop, then i am afraid you would have to call for service to check whats wrong in the system.
Thanks and do tell if this solved your problem.
Feb 10, 2010 | HP Computers & Internet
One Short beep and two long beep
The beeps you hear are BIOS Beep Codes. Sort of like a Morse code, if you know what that is. Every computer has it's own BIOS program, and version of that program. Each BIOS has it's own Beep Codes.
Taking a guess, as I don't know what BIOS program or version you have, it sounds like a ram memory issue.
Suggest you,
1.Unplug the computer
2.Open the computer case
3.TOUCH the metal frame of the open computer case, to relieve you body of Static electricity. Static will silently fry out your delicate computer hardware components. You won't see it or feel it.
4.Remove the ram stick/s. Reinstall the ram stick/s. (Stick/s means one ram stick, or two, three, or four ram sticks)
You may have just had a loose ram stick.
Apr 28, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Blank screen long beep 2 short beeps at startup.
The 1 long 2 short beep code means a problem in the video circuitry and the laptop can't initialize the display. This is usually caused by failure of the integrated video chipset. Unfortunately, on a laptop you can't just open the case and install a new video card like you can on a desktop. You need to replace the mainboard. Replacements are available online. Here is one source found by a Google search. (I'm just using this as an example. I haven't dealt with this site.)
The 4 beep code means no memory detected when the computer started up. No surprise there since you had taken it out.
Apr 23, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
MSI KM2M Combo-L (MS-6738-010) Motherboard Logo
358 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
