Question about HP PSC 1610 All-In-One InkJet Printer
Printer is not printing
The printer is saying no tech mode, paper size error paper size detected is not supported.also erroe 0x841270671: hc
  • hsumeiling Jan 12, 2009
    Other than No Tech Mode, it also says cartridge stalled...
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Hp5550 error 41.5 every time I try to print double sided.
Make sure the print driver settings say it is printing the right size of your paper. It may have paper blocking a sensor or the sensor is bad.
Nov 04, 2017 | HP LaserJet 5550 Printer
Paper size detected not correct
What size paper you are using? if you are selected 4*6, you have to use same paper right?, pl clarify
Feb 02, 2012 | HP OfficeJet 7310 All-In-One InkJet...
When I want to make a copy it tells me "Paper size
Good day, Regarding the error message that your getting, that means the paper where you want to print that document is not supported by the printer. Usually you'll the see supported paper size if you click the print option or print setup for your printer. The only way to resolve this is to use the appropriate size of paper like.
You can also try this steps to change size for the documents you want to print
>Open the File menu and click Print.
>Click the Settings tab
>Click on Paper Size. A list of paper sizes will appear
>Select the size you want.
>If none of the selections are suitable, select Custom. A box will appear inviting you to set your
own measurements. Enter the width and length that you want.
>Click OK.
These are the usual paper size use. It's 8 1/2 by 11 inches and the other one that you could use in most printers is 8 1/2 by 14. The first one is known as Letter size, the other one is known as Legal size. Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | HP Photosmart 3310 Printer
The kyocera km-2550 is giving me an error "Print Mode Erro"
go to printer properties, printing preferences and set the paper size to A4 or the size you are sending
Sep 07, 2010 | Kyocera CS-2550 Black and White Copier
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
When i start my printer it has an error sign
I think this is a paper size error code. Im not sure how to overcome it. Try reinstalling the driver and/or see if HP has a updated driver for your 1610v
thanks for your question
Jan 04, 2010 | HP PSC 1610v All-in-One Printer
It doesn't print It says size paper error
This problem occur when ink head is dirty and also the head cleaning plastic mechanical cleaner is full of jammed color. 3210 model can be opened and the ink head plastic cleaner can be changed. The ink head is the moving part on the metal axel.
Isopropanol is good for cleaning.
Oct 06, 2009 | HP Photosmart 3310 Printer
Paper size error
What that means is that you put in a size of paper that your printer can't use. Apparently, the paper you loaded was detected by the printer and was recognized as being a size it isn't designed to use. HP.com has a web page for your printer that tells you which paper sizes you can use for your printer.
Product Specifications
When the web page opens, scroll down to the Paper specifications area and look for the Paper sizes table. Use only the paper sizes that are listed there in your printer. Good luck.
Oct 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Jun 09, 2008 | Canon imageRUNNER 210S Copier
PAPER SIZE DETECTION ERROR
Are you tring to use a paper tray or the manual by pass tray?If you are tring to use a paper tray for more then one or more copiers, you are going to have to ask your service techs to change the setting of one of your paper trays to A4 in service mode. Or if that has been done, look behind the paper trays for a wade of paper blocking the size detect switchs behind the paper trays. Good Luck
Mar 03, 2008 | Canon CLC 1120 Color Copier
HP PSC 1610 All-In-One InkJet Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
