Question about Samsung Washing Machines
I just purchased a Samsung WA10F4 washing machine. It appears to only have a screw type levelling adjustment on one foot.
How is this machine levelled without using shims?
SOURCE: water doesn't stop filling when selector switch is on Super (GE)
replace water valve
Posted on Oct 12, 2007
  • 249 Answers
SOURCE: Water fill level is incorrect, probably faulty pressure switch.
don't touch the screws 0872465395 Ire
Posted on Dec 30, 2007
AlmostBob
  • 550 Answers
SOURCE: Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Posted on Apr 29, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
SOURCE: EZI Sensor is unbalanced on every load
Problem now solved, Simpson solved it by informing me that this machine comes with 4 transit straps on the bottom of the bowl to the adjustable feet. Its not stated anywhere on the material supplied.
Posted on Dec 16, 2009
My SAMSUNG washing machine model WA10F4 won't open water inlet. Please advice on what to do..need it badly. Kindly suggest where to bring for repair.
seems like the water inlet solenoid isn't working you may contact samsung directly to have a repair man fix the issue since samsung has all the parts for their washers
Feb 26, 2017 | Samsung Washing Machines
HOW DO I FIX OUR SAMSUNG WASHING MACHINE MODEL WA10F4 WHICH FAILS TO AUTOMATICALLY START
you will need to replace the main pcb to fix it. I'll attach a video on how to do it. You should be able to get the part cheap online. Umina Beach Appliance Repair
Nov 11, 2015 | Samsung Washing Machines
Samsung washing machine model Wa10f4..cannot spin..in a cycle wash ang rinse ok..what can i do.
There are many things that can cause a washer to not spin...the
first place to look is the belt. Is it loose or broken?
Regards,
Dennis
Aug 17, 2014 | Washing Machines
WA10F4 8.0 kg samsungTop Load Washer appear error is 4E
Load was out of balance. Slow down the spin speed and take more items out.
Aug 13, 2014 | Samsung Washing Machines
How to level a samsung dishwasher?
Usually the front legs can be adjusted by just turning them. The 1 back leg (Samsungs use a tripod foot support system), is adjusted through a remote screw-type leveler that is located in the center (left-to-right) of the base, just behind the toe-kick panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 30, 2014 | Samsung Dishwashers
8.0 kg wa10f4 samsung diamond drum
I NEED TO KNOW WHAT SHOULD I DO WITH MY SAMSUNG 8.0KG WA10F4 DIAMOND DRUM IF THE WATER FROM THE TUB IS NOT DRAINING..AS IF THERE'S SOMETHING STOPING THE WATER TO FLOW
Jun 02, 2012 | Samsung Washing Machines
My machine is on a concrete floor and when the spin cycle comes on it vibrates all over the place,how do i fix this?
Hi from France,
All washing machines need to be 'level' and not able to rock. Spin cycles tend to show unballanced/level machines 'best'!
Is it possible that the concrete has been worn in some place(s) under the feet? If so:-
There are (normaly) 4 feet and at least the 2 front ones are adjustable- sometimes all 4 but the rear ones are difficult to get at!
You need to ensure that the front feet are adjusted/screwed down tight to the floor. In my experience washing machines are delivered with a flat spanner to facilitate otherwise an adjustable will be required. If one foot is easy to turn THAT is the one which needs screwing down until it becomes fairly difficult to turn further. Check by rocking the machine fairly hard- without moving its position on the floor.
Hope this cures,
Cheers,
John C
Jan 23, 2011 | Kenmore Front Load Washer
Machine seems to have balance off with every load and beeps.
Make sure that the washer is completely level. If it is not, adjust the foot screws.
May 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
