Question about Sewing Machines
Bobbin won't wind on Bernette 56 - Sewing Machines
  • 76 Answers
SOURCE: bobbin won't wind correctly!!
Iam very picky about my bobbins!
make sure you are threading the machine for the bobbin correctly, In my opinion I don't think any machine really winds well.
What I do is hold the thread about an 1" away from the bobbin. start to wind and I guide the thread slowly up and down the bobbin so that it winds even
Posted on Aug 28, 2009
bargainbox
  • 1388 Answers
SOURCE: Please walk me thru winding the bobbin on a
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Sep 04, 2009
  • 5481 Answers
SOURCE: I was given a Bernette
The Bernette 50 is by Bernina. There are several online sources of the bobbins. Try http://www.gonesewing.com/servlet/Detail?no=144 . Otherwise look for the SA156 bobbin for Brother machines (http://www.sewinginusa.com/products.asp?id=2275 ) .
You can buy a manual for the machine here: http://www.sewusa.com/Sewing_Machine_Manuals/Bernina_Manuals/50_60_70_75_Instruction_Manual.htm .
I hope this helps.
Posted on Jul 22, 2011
Tally Girl
  • 1133 Answers
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Posted on Aug 02, 2011
SOURCE: Can't get bobbin to wind on bernina 707 minimatic
Is you question about how to 'wind thread in a bobbin'? If so download this manual http://www.berninausa.com/webautor-data/486/BERNINA_707_717_manual.pdf (al though the pictures are not clear, the first image shows each part with numbers)
Its just above the machine at the right side. See the first image in the manual numbering each parts, its the 14th part 'Bobbin Winder Spindle'.
And if you are looking for parts go to this link http://www.sewingpartsonline.com/bernina-707-sewing-machine-parts.aspx
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Posted on Aug 19, 2011
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Bernette 56, can't wind the bobbin thread, the spool not releasing the thread!
check the bobbin tension for the thread size you are using as it requires adjustment for different threads
Jul 06, 2014 | Sewing Machines
Bobbin won't wind and display shows me in bobbin wind mode and won't turn off, so i can't use the machine at all
it sounds like it's a problem with the computer motherboard and the
machine needs to be checked
Dec 04, 2012 | Sewing Machines
My bobbin won't wind the tread
Did you remember to put your brother into winding mode?
Dec 02, 2012 | Brother XL-2230 Mechanical Sewing Machine
Bobbin winding on screen won't come off
Did you remember to slide the bobbin winder pin all the way to the left?
Sep 25, 2012 | Janome Memory Craft 9000 Computerized...
How to use elastic thread in a Bernette 66
Did you change the needle to one designed for elastic thread?
Aug 21, 2012 | Bernina Sewing Machines
Bobbin won't wind on singer 5500 just makes motor noise
the machine probably needs to be serviced
Apr 13, 2012 | Sewing Machines
Please walk me thru winding the bobbin on a Bernette 65 sewing machine
Sep 03, 2009 | Sewing Machines
Sewing Machines Logo
90 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
