Question about Garden
Rope caught in the pulley that drives the mower blade. Blade pulley is stuck.
It got caught on some nylon rope
  • 15 Answers
SOURCE: BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
Posted on May 28, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
mowerman1857
  • 389 Answers
SOURCE: mower shuts off when blade is engaged or when the
Sounds like a bad safety switch and since it is caused by both the blade and the transmission, I would check the seat switch. You can temporarily bypass it using a short jumper wire on the harness plug, unplug it from the seat switch, put the jumper wire across both contacts in the plug and see if it solves your problem. If it does, replace the switch
Posted on Sep 14, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere lt 133 mower with a double blade
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Posted on Nov 14, 2009
  • 5370 Answers
SOURCE: Need a belt diagram for
So as per your explanation, it indicates that , your mower has 6 pulleys.------ 1 motor driven pulley,3 blade pulleys and 2 accessory pulleys.That in total comes to 6.So for belt routing diagram for Murray 46" 6 pulley.Click this link below and see the belt routing diagram:---
http://technoanswers.blogspot.com/2011/09/belt-routing-diagram-for-murray-pro-16.html ----------- this will help.thanks.Helpmech.
Posted on Sep 05, 2011
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
My lawn mower blade is jam and also thrope is stuck
The stuck rope is holding the Crank from turning. The crank is what the blade is attached to. Disassemble and fix the rope area and blade issue will be solved
Jan 22, 2014 | Garden
Ignition/no spark on ford GT85 riding mower with a kohler M18QS gas engine. I need the electrical schematics for diagnostics.
follow this steps and fix it. GOD BLESS YOU
If grass is poorly or unevenly cut, try mowing at a slower speed and adjusting the engine speed with instructions in your owner's manual. Scrape away any dried grass and other debris caked under the mower deck. Sharpen or replace dull or bent blades 0fbc95da-10ce-4268-a804-bcc52ffe7dcf.jpg. Check and replace a worn belt.
If the V-belt slips or comes off during use, clear any debris in the belt area, adjust the drive-belt tension (see below), or have the belt replaced. Adjust and tighten pulley fasteners or have a service center replace worn parts.
If the belt squeals or wears excessively, adjust the drive-belt tension (see below) and look for obstructions around the belt. If that doesn't work, take the mower in for professional service.
If the mower vibrates excessively when the clutch is engaged, scrape away any debris accumulated under the deck. Balance the blade and replace the blade if needed. If that fails, adjust drive-belt tension (see below). If you find that the drive belt, pulley, or other belt-drive part is damaged, consider having it replaced by a professional.
If the mower is hard to shift or doesn't move when the clutch is engaged, adjust the drive-belt tension (see below). Also make sure the mower is lubricated according to the owner's manual specifications. As needed, have the mower serviced for damaged or maladjusted clutch/brake pedal linkage.
If the engine doesn't start, loses power, or dies during use.
Replace a recoil starter rope:
  1. Disconnect the spark plug cable for safety.
  2. Disengage the throttle cable from the housing and remove the housing as needed to access the starter.
  3. Remove the handle from the rope, which is often held in place by a knot or retainer pin.
  4. Unfasten the other end of the rope from the starter using pliers or a cutter as needed.
  5. Knot the end of the replacement rope.
  6. Tighten the pulley counterclockwise all the way, then back it off two turns and hold it firmly.
  7. Thread the unknotted rope end through the pulley hole.
  8. Thread the rope through the housing hole and pull it taut.
  9. Slowly release the pulley, allowing the rope to wind around the pulley.
  10. Attach the handle and reassemble as needed.
  11. Reconnect the spark plug cable.
Replace a recoil starter spring:
  2. Remove the housing and the spring cover.
  3. Carefully remove the rope from the pulley to release spring tension.
  4. Remove and replace the spring as recommended by the manufacturer.
  5. Reinstall the pulley, rope, and housing following the instructions above.
  6. Reconnect the spark plug cable.
Nov 12, 2013 | Garden
New self propelled front wheel drive mower quit running and you can not pull start rope, it has gas & oil & spark plug is connected and we are holding blade control (gas) handle back
seized up take out plug pour oil in cylinder then hold up blade brake on it side work blade back and forth till it frees up and pull with the rope a couple of times then put plug back in then start it
Jul 30, 2013 | Garden
PULLEY FOR RIDING MOWER BLADE IS CAUGHT ON SOME NYLON ROPE AND APPEARS TO BE FROZEN
Remove the blade, the pulley should free up so you can clean it.
Nov 30, 2012 | Garden
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I own a craftsman LT 2000 17 HP it has worked well and as a rule I am pleased however recently I changed my blades and encountered a problem in that the laft bade turns slower than the right the result is...
Hi and welcome to FixYa, I am Kelly.
You assessment of the problem is pretty much on the mark. Here is what you should do to check the bearing.
1. Remove the belt from the suspect deck pulley
2. Reach under and try and teeter the blade by gripping the end of the blade and lifting it up and down. (None allowed but compare it to the good blade) Watch both the under side of the mower deck for movement and the upper side pulley of the mower deck for movement.
3. Spin the blade by hand and feel the blade bearing upper housing as it spins You should NOT feel any rumbles, strange vibration or odd noises as the blade is rotated.
4. Wrap a nylon rope around the drive pulley like a starter recoil tightly, tie it off and try and rotate the blade. Reverse your nylon rope wrapping direction and do this again. If the blade moved and the pulley does not move most likely the shaft key in the blade adapter has sheared or is missing. (You can try this test with the belt on....also vs using a rope. I find that I still have to tie the belt together to keep is from rotating.)
By doing this you are going to identify the problem.
Thanks for choosing FixYa,
Kelly
Apr 13, 2011 | Craftsman Garden
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
When try to pull on the rope to start the mower is will not move. It feels like it is stuck. But I can move the blade around. Thank you
I thing the recoil spring is stuck it may be rusty. Its time for a complete maintenance on this mower. But you could try tapping the top of the recoil where the rope coils up into. Bang it a few times as you pull on the rope. this may free it up. Good luck DFD
Apr 20, 2009 | Garden
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
