Question about Redcat Racing Earthquake 3.5 1/8 Redcat R/c Nitro Monster Rc Truck
Earthquake 3.5 Starting tips
If your like me and are new to nitro you may get frustrated trying to get it started at first. I spent the last 3 days checking over everything on my truck after doing a rebuild and couldn't get the truck started.
First thing you should check is your glowplug, if you put that in your igniter and it glows nice and bright then it is fine and put it back in.
second thing is, are you priming the engine fully? maybe give it another 1 or 2 pulls while plugging the exhaust to be sure. If it still wont start you should move on to checking your intake.
How much of a gap is there in the carb when you take the air filter off? I had to open mine up a little more to get it running properly but every engine is different.
If you are still having problems you may need to adjust your carb needles slightly. The factory settings will not work for everybody.
As long as you have good compression (you should feel resistance in the pull cord) you should be running by now.
Where I recently did a rebuild I checked over all of the screws EXCEPT the head which was causing me to lose compression and it wouldn't start.
If you don't like maintenance,troubleshooting or repairing then this is the wrong hobby for you!
brainyass
  • 242 Answers
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Posted on Sep 17, 2008
  • 14 Answers
SOURCE: What battery do I need
Black and Decker has owners manuals you can download or just veiw on screen, which give part numbers for all Vector units. Hope this helps ! Matthew
Posted on Jan 22, 2011
rpq2112
  • 6 Answers
SOURCE: we were breaking engine in, was running great
What does it do when attempting to crank
Posted on Mar 06, 2011
SOURCE: the volcano breakes do not
I just got my Volcano S30 Friday, breaks worked great for 1 run not full speed, second run low speed no breaks at all, adjusted the linkage as requested by red at racing breaks worked good for 1 run then same thing no breaks, manually checked the breaks by hand the pad stops like it should except the wheels keep turning and the drive shaft as well.
Posted on May 14, 2012
kevin_boyce7
  • 3 Answers
SOURCE: engine will not stay running
Change glow plug first. And adjust to factory settings. Also nitro motors depending on outside temp can vary..
Posted on Jul 01, 2012
Have a 2006 s80. Serviced last month. Got oil and filter changed. Check engine light came on a day before oil change. which it did last year and shut off after the oil change. This time it stayed on.
042 is brake position sensor code. That sensor is used primarily to cancel the cruise control but may also be used for abs, if your car is equipped. Can you get an odb scan to see why the check engine light is on? The engine light does not indicate oil changes, so something else is wrong. We need that code, which starts with P and has four digits after the P.
Jun 23, 2017 | Volvo S80 Cars & Trucks
Tip
on Feb 14, 2014 | Redcat Racing Earthquake 3.5 1/8 Redcat...
Bought this last night...we spent over 1/2 an hour trying to get it to work properly...finally achieved that...now this morning... 1) I can't get the water to heat up, 2) it keeps turning off, 3) as...
Clearly, your issues are related to issues that can only be corrected at the factory.
Keurig Customer Service: http://www.keurig.com/customer-service
Dec 18, 2010 | Keurig Platinum B70 Coffee Maker
Everyday my truck starts Hot,Cold, Snow, Sun... This morning it refuses to start. Cranks Cranks Cranks but wont start. Rained like a banshee for the last two days straight but it's been trough that a dozon...
Hello bud, just noticed ur post. So if u have not fixed this yet go to the part store and get a new (cap and rotor) Mine just did the same thing during a snow storm and i take extra care of this truck everything works and i spent days tracking this down but believe me it is the problem... i spent around $100
Mar 15, 2010 | 2003 Chevrolet Silverado 1500
No spark no fuel no start! replaced and checked everything,fuses,grounds,relays,coil, plugs,wires,distributor,crank sensor,jumped fuel pump, works. timing right on, last code given was P1500, changed fuel...
funny thing is I have a 2002 GTI with the exact same problem. have spent the last three days at work trying to figure things out.. best of luckn email me if you figure anything out. Beattie411@gmail.com
Dec 23, 2009 | Volkswagen GTI Cars & Trucks
No spark after cam sensor replaced - Frustrated!
hallo
check sensor: disconect conector. you have 3 wires. first(green) and last(black) are suppy should be around 5V. if not check wiring.
If ok: conect conector and access conector terminals (or wires) and conect LED test lamp between terminal 3 (black) and 2 (also black).briefly krank engine. Check that LED flashes.
hope it helps
Marko
Sep 10, 2009 | 2006 Fiat X1/9
Dodge Nitro unhappy
lemon laws are a little different in all states, but the basics are- the dealer has your vehicle 30 business days in the first 12 months of ownership. 3 unsuccesful repair attempts at the EXACT same problem, that resulted in you returning with an unfixed problem after thinking it was fixed. i have not seen any problems with nitro's yet. what problems are you having?
May 15, 2008 | 2007 Dodge Nitro R/T New Cars
Redcat Racing Earthquake 3.5 1/8 Redcat R/c Nitro Monster Rc Truck Logo
16 people viewed this question
Top Redcat Racing Toys Experts
ray gallant
Are you a Redcat Racing Toy Expert? Answer questions, earn points and help others
