Question about Hotpoint Dryers
REPAIR BELT ON HOTPOINT MODEL # DLB1550RALWH
THE DRUM DOESNT TURN
4 Suggested Answers
  • 91 Answers
SOURCE: dryer runs but drum doesn't turn
if not turning repl.belt
Posted on Jan 04, 2009
hunter19_46m
  • 7482 Answers
SOURCE: husband just changed belt on dryer, and drum still doesnt turn
While you have the drum out check the motor to see if it runs. It could be you have a faulty motor.
If the motor is running then you may have a faulty timer or start switch
Good luck,
I hope this helps
Posted on Oct 28, 2009
oldmanewtoys
  • 414 Answers
SOURCE: we have a hotpoint dryer
take off top ,should hing from the front,just pop it up with screw driver
Posted on Mar 05, 2010
Drum doesnt turn
hi is the belt on if so 1st thing to check are the motor brushes good chance thats the proplem
Dec 27, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
The power turns on but drum will not turn
sounds like ur belt dat gose around ur drum and d motor has snapped easy cheap fix open it up and get d number of d belt and ring d manufactor tell dem d number and order new 1
Jun 26, 2012 | Frigidaire Electric Dryer
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
Model: DLB2650BALAD Problem: Heats-Drum does not turn Solution:?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 24, 2010 | Hotpoint Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Hey when we turn on our dryer we get a burning smell and the drum doesnt turn, any ideas? we think the engine might have burnt out?
Either something is binding the drum, or the motor has failed. Can you turn the drum by hand? If you can, then most likely the motor has failed, if you can't turn it by hand, then the drum is stuck and the motor just isn't able to turn it until you find whatever is binding the drum. You might have to remove the back panel to get in to see what might be causing the problem if it is binding.
Let me know what you find with this.
Benjamin
Feb 06, 2010 | Kenmore 62602 Electric Dryer
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
I have replaced the belt on my Hotpoint vdt00 dryer but the belt seems to pull the drum on to the motor causing a scraping noise and its hard to turn around. their dosnt apear to be a bearing or anything...
look inside the drum is there three screws on the very back wall of drum,there is a bearing there,remove the belt,slide the drum forward and look at the back of the drum,there should be a shaft sticking out that slides into a slot that looks like a U in the back wall,that is the rear bearing that you get in a kit if you hear a loud squeaking sound that's the problem,if you sent the model number i could of told you the part number
Dryers Logo
115 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
