Question about Linksys Wireless-G Broadband Router
I need the password for wireless signal from my linksys broadband
My laptop picks signal but needs password in order to access internet. How can get the password?
    Problem Solver:
  • 11 Answers
Unable to print from repeated wireless network
If you have done it properly there is no need to bridge networks because there should only be one. The entire idea of a repeater is to simply pick up the signal from the first router and rebroadcast the signal.If you had included the model of the repeater I could have been more specific but as it is, read this: Linksys Official Support Configuring an Access Point as wireless repeater
May 13, 2017 | Cisco Linksys WirelessG Broadband Router...
I have a linksys wrt54GX2 wireless G router and I would like to use it as an access point to pick up our internet signal from downstairs. The modem in use is wireless motorola SBG900. I have a desktop and...
With that particular model you wont be able to use it as a wireless bridge. You can however run an ethernet cable from the modem to any point in your house. the SBG900 i believe has wireless built into it, so you may need up with 2 wireless networks.
Hope that helps.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Im trying to set up internet for my ipod touch and it wont let me access internet without the linksys password and the model in wrt54gs... how do i find my password
Yes, you really need a password for that (either WEP or WPA). You can ask for the password to the one who configured the router. They placed a password for security reasons. In order not all people can access net, only those who knew the password.
Jan 03, 2010 | Linksys WRT54GS Wireless Broadband Router...
Can't find security code for router
Security default is admin for username and admin for password.
You can access your router by typing 192.168.1.1 or similar in your internet address bar to access router's programming
Sep 02, 2009 | Linksys Wireless-G Broadband Router
I have good internet signal from cable modem and laptop detects router at 46 Mbps but can't access internet wirelessly
  • Is your computer connected to the wireless router
  • If you are able to see the router, maybe you need a security code to access it.
  • disable and enable your wireless on your computer.
Do hope 1 of the above helps.
Aug 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I have a Linksys Wireless-G Broadband Router and want to connect it to, the only computer in the houuse, my laptop. How do I make a wireless connection for the laptop? It is picking up the router's signal,...
You need to make sure your router is set up correctly, as well as your internet connection, whether it's cable modem or DSL or whatever.
First of all, what kind of internet access do you have?
Jun 16, 2009 | Linksys Wireless-G Broadband Router
Can not get the second laptop on the internet with the wireless
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Dec 26, 2008 | Linksys Wireless-G Broadband Router
Cant connect to internet from laptop
The network key is stored in the router, and your manual will tell you how to access it.
If you don't have access to the router's web page, you'll need to reset the router and start over.
Dec 20, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
