Question about GE WSXH208A Front Load Washer
Final Spin Drum BANGS around--terribly frightening noise!
I have a GE WSXH208A1WW that is about 6 years old...was running beautifully until I overloaded it with sheets towels and regular clothes. On Final Spin it started making a dreadful noise so I shut it off. I unloaed the towels and sheets and set it back to final spin--noise continues. We took the back off and nothing seems out of the ordinary...we're not sure what happened but can't afford to call in a service call on it...we are a desperate family of 5 that needs our washer back... :( Any solutions? I'm not familiar with the parts of the washer so details would be greatly appreciated. :)
  • threelilmacs Jan 11, 2009
    Thanks for your advice...I think you are correct it sounds like a train with nothing in it...it still works per say...are the bearings just to make it quiet? Would there be any danger if we continued to use the washer and ignored the loud banging and noise?
    Thanks very much for your feedback...we truly appreciate your help!
Check the spring that hold the drum in place. They are about 4-5 inches long on the top of the drum at about 2 and 10 o'clock. The springs suspend the drum and if broken the drum will bang around. About $40 to order springs online
Also check on the bottom at about 4 and and 7 o'clock because there are 2 shock absorbers that help keep the drum from just bouncing and bouncing with no end in sight. Again about $40 to change each one.
I am in the process of the first repair and doesn't seem too difficult. The second was done about 6 months ago and was not too difficult but was awkward because you had to lay on the floor to get the replacement pins in place.
Posted on Jan 12, 2009
    New Friend:
  • 88 Answers
Have you tried running the unit through the spin cycle with nothing in it? I would try that , but Unfortunately bearing (the whole back half of the washer) on those units usually last about 5 to six years then the go bad and start sounding like a train. if it makes that loud noise with nothing in it don't bother paying for a service call. I hate to break it to you better you hear it from me here then after my company charges you 90 bucks for me to tell you it will cost 1000 to repair. good luck let me know what happens.
Posted on Jan 11, 2009
  • Dean Rhymer
    Dean Rhymer Jan 11, 2009
    It eventually will stop spinning. The tub will break trust me you will know when this happens.From my experience with these they have not been dangerous just annoying. If you have to use it lower the spin speed and run small loads. but I'm sorry there is no time frame on how long you have. start saving good luck.
GE Electric Dryer 8 years old - white paint peeling off dryer drum. Any idea why?
it may have been painted b4 you purchased it and the heat degrades it
Feb 21, 2015 | GE Dryers
SAMSUNG TOP LOAD WASHER (ONLY 3 MTHS OLD) WILL NOT COMPLETE SPIN CYCLE. IT STOPS BEFORE GETTING TO FULL SPEED, REPORTS AN OFF BALANCE ERROR CODE. IMPOSSIBLE TO BALANCE - FROM TOWELS, SHEETS, REGULAR...
You could be having a problem with your hall sensor. I would recommend you call Samsung for a warranty service call. The machine should have a 1 year parts and labor warranty so let them fix it for free.
Sep 16, 2013 | Washing Machines
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
GE front loader keeps tearing clothes
You are overloading if that is all that it happens .....less clothes more water and set the cycle for delicates...... unless the clothes are coming out stuck around the agitator than thats a different prob....
Jul 22, 2009 | GE Washing Machines
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Jun 07, 2009 | Whirlpool Washing Machines
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grease on clothes?
This is a 50 year old problem on washers.  All brands.  You just got lucky on this one.
If you buy a new one, consider a unit built by Whirlpool.  They also make Kenmore and others.
Nov 12, 2008 | GE WSXH208A Front Load Washer
My washer wont do the final Fast Spin
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Do this - I had the same problem and this fixed it. It takes about 10 minutes.
Oct 27, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
894 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
