Question about Sharp 27R-FS1 27" TV
Tv keeep blowing the fuse
One day the dish and two out of four digital boxes got damaged and the tv blew the fuse. I replace the fuse but it keep blowingit out. no image and no sound from tv.
    Champion:
  • 240 Answers
Simpel fix replace the 4 bridige diodes.\
parts cost about $8.00 and labor shold be about $60 shop around for best repair shop pricing.
Posted on Jan 11, 2009
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
15 amp a/c clutch fuse keeps blowing. why is it doing this?
Sounds like the magnet in the a/c clutch has failed.
Jul 02, 2012 | 2001 Oldsmobile Aurora
1991 jimmy 4x4--canada
If the windshield is still leaking use a water hose and run it over the outside till you find the leak, and seal it with windshield adhesive. Moisture is bad for the fuse box. You may want to pull the fusebox out and inspect for damage behind it-melted or burnt wires, terminals, or connectors.
Sounds like you're on top of it. Just stop the leaking and clean up any damage and you should have it. Good luck.
Jan 10, 2012 | 1991 GMC S-15 Jimmy
Amp keeps blowing fuses (alpine mrdm1001
Hello prabh_dusanj,
First make sure that the amp is not operating into too low of an impedance. If the load is OK, it's most likely a short in the output transistors.
Hope this helps.
Sep 11, 2009 | Alpine MRD-M1001 Car Audio Amplifier
The engin control fuse keeps blowing on my 2005
your fuelpump could be causing the fuse to blow as it may be seizing up
Apr 18, 2009 | 2005 Ford Focus
Fuse Keeps Blowing
Replace the lighter assembly, it is shorted, this is very common.
Nov 26, 2008 | 1991 Lexus LS 400
70a fuse in main box keeps blowing
dead short in wiring, maybe or fan moter is stuck or will not turn causing fuse to blow? can you smell wiring getting hot> or brushes shorting in fan moter.
Jun 25, 2008 | 1989 Honda Accord 4 Door
Transformers and fuses keep blowing
If you are where it's warm and you are using air conditioning, have the technician check the coil in the relay in the outdoor unit. I replaced 2 transformers before I figured out the coil was shorted out and drawing too much current.
Jan 04, 2008 | Goodman GMS90703BXA Heater
Outside transformer blew, now TV doesn't work
I hope is only a fuse and it will not be hard to find it should be close to where the power cord goes in and it has to be replaced with the same amps and size.Make sure the set is not plug in whe you remove the lower back and once you replace it put the back cover on and plug it in,if more damage is present it will blow up again right away or it will blow up when you push the power button,I hope it doesn't but if it does you will need someone qualified to check the rest.Be careful
Sep 22, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Sharp 27R-FS1 27" TV Logo
59 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
