Question about JVC KWAVX840 Car Video Player
JVC KWAVX840 replacement
My touch screen is cracked and i want to know where i can get a new detachable face plate
3 Suggested Answers
SOURCE: I have a JVC EXAD
i have no disc with my jvc exad but i want to put my own pictures on it how do i do it
Posted on Jun 07, 2011
nicole_richi
  • 5 Answers
SOURCE: need a replacement faceplate for a JVC KW-AVX730
have you tried to contact jvc and get it fixeed under warrenty?
Posted on Jul 17, 2012
What to when my Alcatel 991D does not sense at all when touching the screen?
I don't think this is a breadmaker but rather a touch screen mobile phone. Check the screen for cracks . I have a mobile phone that I dropped and cracked the Liquid Crystal Display. It does not sense the right hand side of the screen. It took me 2 days to figure out the screen was cracked as it was hard to see the crack.
Nov 26, 2014 | Kitchen Appliances - Others
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Oct 18, 2010 | JVC KW-NX7000 Car GPS Receiver
Cracked touch screen on in dash reciever
a new face plate costs 110.95
store is called partstore.com
part # TDF-719DVD
Jan 25, 2009 | Kenwood KVT-719DVD 7 in. Car Monitor
Singer touch and sew 648
Thread the machine as if you were going to sew. When you thread the needle, pull the thread off to the left and wrap it around the thumb screw on the left and just above the needle. Wrap it only 2 or 3 times and hold the end of the thread. With bobbin in place and the face plate slid open, push the thumb lever on the left under the face plate to the left. Begin to 'sew'. As you do, the bobbin will wind and the thread you are holding will detach. Once the bobbin is full to the outside line, slide the face plate the closed position. As it closes, it will release the thumb lever. Put the needle in the slightly lowered position and slide something blunt under the pressure foot pulling thread from both the bobbin and the needle; cut the thread when you've pulled it out sufficiently.
Jan 19, 2009 | Sewing Machines
My screen has cracked and ive just purchased a new screen to fit i need to take the old plastic screen off
Very Carefully! ... jk lol
1. You'll want to begin by removing the top plate cover of YOUR laptop/notebook illustration below.
2. keep trac of every screw or **** or metal item you remove
3. You'll next want to detach the display ribbon cable , this is just an example
4. finaly you'll want to remove any OTHER ribbon cables , exampe below.
5. now for the tricky parts , you'll need to make sure you DO NOT PRY anything open
keep searching for hidden screws that may be located underneith plastic covers
that parts very tricky because sometimes they disguise them very well
6. once you find the screws to remove the face plate , illustrated below you'll be able to install your
new display screen without any farther assistance.
you do not need to remove the metal rods that hold the display in place , you just want to remove the face plate like this example below.
Thank you for using FixYa!
Loch Hiam
Az.
Sep 17, 2008 | Computers & Internet
Ppc 6670
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. Be certain to order the correct piece.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Jul 03, 2008 | Audiovox PPC 6700
DETACHABLE FACE PLATE
You cannot purchase a new faceplate. you will need to replace the entire unit.
Apr 30, 2008 | Pioneer DEH-P3500 CD Player
Detachable face plate for DEHP47DH on and off buttons and other function buttons not working.
make sure the connections are clean on face plate and base make sure no grease or anything like that failing this then contact the makers or even place of purchase usually as long as you have the face plate and the whole unit they will replace the face for free but you might need to show them both as stolen ones people were getting the face for free so they stopped this so get in touch with makers or even place of purchase they should replace for you.
How old is device?
Have you tried pushing the face in whilst pressing it on further just in case the connections are not touching.
Do any buttons work?
Apr 21, 2008 | Car Audio & Video
JVC KWAVX840 Car Video Player Logo
80 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
